Here is a link to the pdf format owners manual from Uniden for this phone:
http://www.uniden.com/pdf/TRU8885om.pdf
Remote Operation
You can check, play, or delete messages, even record a new greeting message from a
remote location (when you are away from home, or from another room using a
handset). Additionally, you can turn on or off your answering system remotely.
Remote access away from home
You can operate your answering system from a remote location using any touchtone
telephone.
1) Call your telephone number and wait for the system to answer. If the answering
system is off, it will answer after about 10 rings and sounds a series of beeps.
2) During the greeting message (or a series of beeps when the answering system is
off), press 0 and enter your PIN code within 2 seconds (see "Setting a PIN Code"
on page 25).
3) The answering system announces the current time and the number of messages
stored in memory. You hear "To play incoming messages, press zero-two. For
help, press one-zero." You will hear a beep.
4) Enter a command within 15 seconds, each command there after must be entered
within 2 seconds. You may select a command from the following chart:
* For the Repeat a Message function, press 0 then 1 within about four seconds to
repeat the previous message, or press 0 then 1 after about four seconds to repeat
the current message.
**For the Memo Record and Greeting Message Record functions, the first time you
enter the corresponding command, the phone starts recording. If you want to
stop the recording, press 0 then 7, 8 or 5.
5) After the command has finished, you hear intermittent beeps indicating that the
system is in the command waiting mode. You may enter another command at this
time from the chart above.
6) When you are finished, hang up to exit the system. The answering system
automatically returns to standby.
Command Function Command Function
0 then 1 Repeat a Message* 0 then 6 Answering System On
0 then 2 Playing incoming Messages 0 then 7 Memo Record/Stop**
0 then 3 Skipping a Message 0 then 8 Greeting Message Record/Stop**
0 then 4 Deleting a Message 0 then 9 Answer System Off
0 then 5 Stop Operation 1 then 0 Help
More info: I can't change the recording speed in Menu. It stays on LP.
After formatting, not only do I get strange character in folder name, I also can't record because it says Folder Full full. After I change folders, the strange character goes away and I get the FOLDER # back again.
I wonder if the electronics is fried on this.
My ds-2 got a little wet. . . now it wont play or record, although all other functions seem fine, and it appears to have full memory of the pieces already recorded. Also, I can't get it to download to my mac, although I never actually did that before it got wet. . . I thought I'd try to save what I have and probably buy a new one. ANy hope? No one seems to repair these things.
I have the same problems: I can't record, and I can't set the Rec Mode to anything but LP. The DS-2 had been working fine for months. Now, when I hit record, the unit beeps once, waits a second, and then fires off a series of 5 or 6 very rapid beeps -- recording never starts.
My Olympus Digital Voice Recorder, model DS2 won't record, I had it plugged into my Mac and just pulled the power cord out to record another phone interview and when I pressed record it just gave me a few short fast beeps and says "READ ONLY". Can you please help?? I am a reporter for a small local newspaper and have a deadline. Also, I lost the prior story I was transcribing...any way to recover?? Help!!!
i formatted my recorder through my PC and now it doesn't recored or play back. can any one help Pleasesss!
