Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
Posted on Jun 07, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fog and dew dripping in ref
I bought a refrigerator (top frezzer, model :GR2FHMXVY) 2 months ago. recently, I see a lot of fog on the wall of the ref drawers and dew drippings at the center close to back.
In freezer, there is a little frost formed at the walls.
the thermo is set to the middle position.
Do you know what is going on?
Mike Squire
Level 3:
  • Master 420 Answers
  • Posted on Jun 07, 2010
Mike Squire
Master
Level 3:
Answers
420
Questions
Helped
258574
Points
1000
It may be high humidity of the air outside of the refrigerator or you are storing highly humid things inside along with the settings of the fridge.
Liking water under the door of frezzer, all the time Mod.= I2569Vem 4 Ser. = KD3545219 Stainless steel, Bottom Frezzer, only a few month new bought in home depot in carolina P.R. Can not find enybody...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Ref practically new, intermittent leak onto floor at left rear ref is model HSM25GFTCSA side by side
check drip pan, if it full of water and there is no heater on this model you need to upgrade it with heater under drip pan.
but check if it's not cracked and drain line goes to it and not on the side...
www.appliancesrepairla.com
Frezzer leaks into fridge
This is usual. In some refrigerators it is designed that way. It will keep the vegetables etc. in the fridge from drying out. Usually this spout is close to the back wall of the fridge. It is designed such that water drips directly to a small hall on the bottom of the fridge. It is important that you don't push the dishes or food in the fridge too far back. Otherwise water will be on you food. This spout should be far back as I mentioned. If, for some reason the water is dripping not close to the back, the spout may have beent damaged or bent. Check to see whether it is OK.
2answers
Hotpoint CTF15ELD top freezer refrigerator - freezer O.K. refrig too warm
It's likely the door was inadvertently left open, and the cold air passages from the freezer have built up enough ice that the cold air from the freezer has no way to enter the refrigerator. Check the cealing of the refrigerator. If you can see or feel ice in the passages between the freezer and fridge, you can probably solve the problem by finding a safe temporary home for your food, and leaving the refrigerator unplugged overnight.
I have lots of ice freezing to the back wall of the freezer side.
it may not be working or it is not set to cycle often enough.you can also check for air leaks.a constant air leak will cause a lot more ice to build up.
Freezer staying cold but defrosting on Kenmore Refrigerator dripping into bottom frig
I bought kenmore refigerator 21 cu.ft. year ago, but recently on top of freeze door side produces ice would you please tell me what's happen and how to prevent.
Sincerely,
Tim Kao
Refrigerator is too cold
You have bad Thermistors they sense the temp in the frezzer and the ref section they are about $15 each and the same part #
Amana bottom frezzer refrigerator
Gazzo, You are on the right track. I've been finding a lot of compressor failures on these Amana's. It's possible that the overload and relay for the compressor failed, but Im more inclined, from what I've seen, that the compressor is the problem. The compressor is covered under warranty, parts and labor for 5 years. I would call for warranty service...Catriver...post back.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
