I have an HP Photosmart Premium C3009 all-in-one printer. Sometimes it refuses to print with a message that says: The process stopped unexpectedly with status 1. I've looked in the manual and find no...
I also experienced the "process 'mdns' stopped unexpectedly with Status
1" message a few days ago with my new HP 7250, and found two solutions.
Here are a couple of potential cures:
I downloaded the shareware program 'Printer Setup Repair', then ran
their 'Reset and Backup' routine. Restarted, and bingo! Printing was
successful. But trying to run either the HP scan software or the HP Ink
Widget from Dashboard were not so successful. Got a 'Scanner not found'
message. I then went to the printer, tried doing a manual scan there,
sending the scan to my PowerBook. Once again, bingo. The scan was sent
to my computer, and now the HP software could see the printer. I've
since restarted both my computer and the printer several times;
printing and scanning are working fine.
Now the second way to fix the problem. It's kind of hokey, but it seems
to work, and is what led me to the The process 'mdns' stopped
unexpectedly" with Status 1" problem in the first place. What you do is
just add an ethernet router, that one you have lying around the house
somewhere, between your DSL or cable modem and your Airport modem. Huh?
Here's the deal: when I first bought my HP multifunction printer, my
wireless setup was this: Cable modem>Xsense ethernet
router>Airport extreme. Unpacked and hooked up the HP printer, and
it all worked immediately, perfectly. Print, scan, check supply levels,
all no problem. Way too easy. Then, about a week ago I realized that
the Xsense ethernet router that I had in the chain was really
superfluous, as we no longer use ethernet in the house; might as well
eliminate that unnecessary link in the chain. So I changed my setup to
a simple: Cable modem>Airport extreme. At this point printing
stopped. Tried everything I could think of, no go. Always got the
"process ' mdns' stopped unexpectedly with Status 1" message. Put the
ethernet router back in the chain, printing/scanning went perfectly.
This made absolutely no sense to me, but it worked.
Left my setup with the extra router for a day or two until I remembered
about the shareware program 'Printer Setup Repair', described above.
Before doing any of these steps it's probably a good idea to run Disk
Permissions (I always run it before and after any installation), just
to be sure you're authorized to be using the HP software.
