There is a "spider" gasket that seperates the different ports inside the multi-port valve. When this gasket starts to get worn, it either comes loose and bunches up, or just plain loses its sealing capabilities. It is easy to fix.
Just remove the pin in the handle. Remove the through bolts holding the lid on the valve, and you will have access to this gasket. You then need to scrape the gasket "seat" clean of debris and old adhesive.
Then, you need to determine the model of the valve you have, and purchase a new gasket, and a new tube of underwater adhesive .
If you need help determining the part number of your valve gasket, please e-mail me the complete model number of the valve to
[email protected] and I would be happy to help you further once I have more information.
To affix new gasket simply put a light amount of adhesive on the gasket seat, then plave gasket in the seat and press firmly around in an even circle. Remove any extra adhesive the oozes out, then put the lid back on and replace the through bolts. Tighten the through bolts down and let it sit for 5-6 hours at least to cure the adhesive.
Then remove the lid again and check to make sure no adhesive has locked anything up, if so clean it off.
Now you are ready to put it all back together and test it out!
Need your complete model number to help .
