After the machine fills the next step is to agitate. By agitate I mean the wash portion. The plastic fin in the middle of the tub rotates back and forth. So, after the washer fills, if the machine does not agitate, but stops dead, you have a broken lid switch. When I say stops dead, I mean no noise whatsoever. If the machine makes noise you have other problems.
If the machine fills, agitates, and then stops dead, the problem is still the lid switch. The next step would be describing the noise so I can more accurately give a suggestion. Problems include but are not limited to: broken couplers, malfunctioning water pumps, and/or defective motors or transmissions. These are the vast majority of the problems, and the others need no mention.
With a model number I can give a part number of the lid switch, and or other problematic parts. Also, I can give you an average price of the parts. With this information you could order it yourself and save money :) The model numbers are located under the lid of the washer. Not physically on the lid, but right under it. Get eye level with the top of the washer and you will see it ;)
