Oven doesnt light and trips the breaker, I replace the thermostate and the spark modual. What can it be?
SOURCE: Surface work but display and oven do not
Bigejpp, start with the basics, On the back of the range where the cord hooks up see if you have the correct power. Three terminals, you should have 120V from each end to center and 240V across the two outer terminals on the terminal block. If you don't have this, the problem is in the breaker. If you do have it, remove the upper back panel and look at the board. You will see L1 L2 and L2 out which goes to the elements. Test for voltage at L1, should have 120V. If you have power to the board and no display, the control is at fault. This is for a 790.95320 electric range. If your model does not beging with 790, most electric ranges operate in a similar matter. Catriver.
SOURCE: FRIDGIDAIRE RANGE
It is most likely the pop came from a relay on the control board if the elements checked ok but not getting power to them. This is fairly common on fridgidaire ranges. Replace the oven control. Usually the control overlay is sold as a separate piece.
SOURCE: viking stove
no the termostat but the ignitor that's the part that's nest to the broiler burner. the part that ignite the flame. when you turn on the broiler the ignitor becomes red like a glow.
SOURCE: burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
SOURCE: Viking Range oven door does not close properly
sounds like the door hinges need replaced. order a part #PC020009 qty 2
