20 Most Recent Viking DEDO205 Stainless Steel Electric Double Oven Questions & Answers
see pics
Viking DEDO205... | Answered on May 11, 2015
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Viking DEDO205... | Answered on Jul 14, 2014
Try to find a relay that has higher contact ratings. Grainger hardware might have one that would fit. It sounds like a design problem and requires a bit of re-engineering to fix it permanently!
Viking DEDO205... | Answered on Jul 19, 2013
If you can take the door apart then you can fix it. Remove all the retaining screws to access the inner glass.
Viking DEDO205... | Answered on Jan 10, 2013
not sure. its possible that something melted into the hinges and glued it shut. or i guess if it got hot enough the metal could have been heated up to a point where it was bent out of shape and thus it got stuck
Viking DEDO205... | Answered on Nov 04, 2010
It could be worn motor bearings, a loose fan, or the fan blades catching the cover.
You are going to have to remove the cover over the fan to determine exactly what the noise is.
If it is worn bearings, then only solution is to replace the fan motor.
Viking DEDO205... | Answered on Dec 16, 2009
No, there is not a fuse on this model. You will need to repalce the clock assembly for this unit. Call us asap and we'll ship the correct part out to you asap so you can start cooking again. We look forward to working with you!
Viking DEDO205... | Answered on Oct 19, 2009
Unplug your oven, and clean both at once., Yes, you can.
Viking DEDO205... | Answered on Sep 26, 2009
A safety feature on the oven door latch is preventing it from going on to clean. Find the reason the door wont latch on top section and it should clean then.
We know your controls are working asking the clean cycle to start because your lower door latches.
SO
Some things to check :
1. Bent or worn out door latch or striker or catch assembly
2. No power to motor to move latch assemble
3. Board for self cleaning may have fuse out or be bad entirely.
4. Motor assembly that moves the latch could be bound up or worn out
If this helps you understand your problem please rate me as high as you can and thank you for using fix ya. Good Luck and God Bless.
Viking DEDO205... | Answered on Mar 27, 2009
Adjust the knob to the actual temperature. There are usually screws inside toe back of the knob for this purpose.
Viking DEDO205... | Answered on Mar 23, 2009
maybe turn power from breaker switch off and wait and turn switch back on see if that doesn't reset oven door lock
Viking DEDO205... | Answered on Mar 04, 2009
Viking DEDO205 Stainless Steel Electric Double Oven Logo
31 questions posted
Top Viking Ovens Experts
Marvin
Marvin
Jose Pino
Colin Stickland
Colin Stickland
Are you a Viking Oven Expert? Answer questions, earn points and help others
View Most Popular
Viking Ovens
  • Viking Ovens
Most Popular Question
fan in oven really loud making
  • Ovens
