20 Most Recent Viking VIPR101 Kitchen Hood Questions & Answers
Folks,
I just took mine a part due to the same problem. I am an EE, so I have some experience in this matter. The problem was indeed the membrane ON/OFF switch. This switch is basically just stuck on the panel like a sticker. You can literally just pull it off and stick it back on. Underneath it is 3 metal "buttons". When you press it, one of these buttons presses on a flex circuit to complete continuity. This send AC line current down to the lift motor under the gear box cover. The lift motor starts moving. After it starts, a cam hits a relay switch, which completes the circuit thru the relay. This is what keeps the vent moving up after you let go of the On/Off Switch.
At first, I through I could just clean the switch up. I figured crud got down in there. But it did not work. I looked at the switch under a microscope, and the problem is the flex circuit was actually burned thru. This is usually caused by a weak spot in the flex combined with too much current. My best guess is this switch is undersized for this application. The switch will also allow current to flow even when the relay takes over, based on how it is wired. I'm not sure I like this, as if one tends to hold the button is all the way up or down, then that just more current thru the switch for a longer time which means more heat and better change of burning thru. Of course if the switch was better quality or design, it wouldn't matter in he first place.
Anyway, I'm going to take the switch to my lab and try and put a jumper wire across the burned area. This probably will not work or it will just burn in another place in the future. So I'll probably have to get another switch. The problem will be finding a good looking one. All one needs is a Single Pole Momentarily ON switch for the application. From it, run the 2 wires the control board connector (polarity does not matter). It is all pretty apparent once you take the top cover of the vent off (4 screws, 2 each side). The cable that runs from the control pad to the unit below uses a S-Video type connector and is keyed, so you can't get it back on incorrectly. Total cost in parts will be very minimal
For you DIY, remember there is AC voltage levels running thru this switch. Make sure YOU TURN POWER OFF when working on it and know what you are doing. You can get shocked.
Mark
Viking VIPR101... | Answered on Nov 04, 2015
WOLF DD36I USER MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Wolf Manuals > Cooktop > DD36I
View and Download Wolf DD36I user manual online. ... cooktop. Wolf downdraft ventilation systems are recommended. for use with Wolf electric ... The downdraft will operate most efficiently when ductwork does not exceed 40' (12 m) in length.
Viking VIPR101... | Answered on Sep 17, 2015
After 11 years of use, the same problem just happen a few days ago - fan keeps running, doesn't respond to the on/off switch. Also cannot reset filter alert. As far as I can tell the entire switch panel isn't working. Or worse, shorted out. Might have to replace the ribbon and some switches.
For example the switches can be found at AllVikingParts.com For example --> http://www.allvikingparts.com/Button_Switch_Assy_p/pv300182.htm
There's a another thread on this forum: http://www.fixya.com/support/t410261-viking_downdraft_ventilator_electrical
I'll post the exact solution as soon as I have it figured out completely.
Viking VIPR101... | Answered on Jul 08, 2010
See the problem and solution at:
Viking VIPR101... | Answered on Jan 31, 2010
You seem to have a slightly different model, but see a solution at:
it is probably the same thing
It's fixable, but it is easier for them to just sell you the whole expensive part. See the problem and solution at:
Hello. Check the electrical panel and find the circuit breaker or the fuse that controls this hood. Chances are that the breaker has kicked or the fuse is blown. IF not, you will have to open up the mechanical compartment in the hood and check to see if the wire nut on the black or the white wire has come off and the connection has been interrupted.
Viking VIPR101... | Answered on Nov 22, 2009
Fixya does not sell Viking dual oven clock control boards.
Viking Kitchen... | Answered 3 days ago
does it have a small metal clip that you have to pull down to release toe kick? (middle, above toe kick)
Viking Kitchen... | Answered on Aug 01, 2018
Have you got the correct supply to it for both ovens to operate? You'd be best off having it looked at by a service engineer, as they can carry out all the relevant checkers to ensure the gas and electric are adequate for the kw rating of your appliance
Viking Kitchen... | Answered on May 31, 2018
Viking VIPR101 Kitchen Hood Logo
19 questions posted
Top Viking Kitchen Ranges Experts
Ismael Rodriguez...
Steve Allison
Steve Allison
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Viking Kitchen Ranges
Most Popular Question
viking downdraft ventilator electrical
  • Kitchen Ranges
