If you hit the reset button and it doesn't get it close, then you have either a cold / fractured solder joint or joints on the convergence IC or IC's. The only fix is to resolder the chip or chips and if that doesn't work, then replace them. But keep in mind that there should be a +21vdc and -21vdc on the chips respectively. If a fuse is open it can cause this type of symptom. So check all the little green pico fuses with ohm meter and go from there. Let me know how that all pans out for you and ....Good luck future technician. Jay Happy holidays.
