20 Most Recent Mitsubishi WS-65611 65" Rear Projection Television Questions & Answers
there are some caps on the signal PCB on the left side of the TV as you look in the back. these will leak(you can tell by the bulges on top...replace these capacitors.
Mitsubishi... | Answered on Jan 03, 2015
Likely has bad 1000UF capacitors on DM module. this will prevent rebooting.
Mitsubishi... | Answered on May 08, 2014
This unit will not indicate any problem without you doing something to initiate the LED diagnostic feature. Go to the front of the set and hit the power button, when that doesn't work hold the MENU and INPUT buttons on the set at the same time for 10 seconds. The power LED should start blinking a two sequence code that will repeat six times. The number of blinks will tell the general area of the problem. As an example a 2 - 2 sequence is a convergence output problem over 95% of the time.
Mitsubishi... | Answered on Jan 20, 2014
IF model number posted is correct and green power light comes on for a few seconds and then goes off:
On front of set press and hold both the Menu and Input (device) buttons at the same time for at least five seconds and release both buttons.
Power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code is found and I will tell you what it means.
SD TECH
Mitsubishi... | Answered on Oct 30, 2013
For model listed here, a issue likely on the Blue CRT circuit board, bad grounds and even seen a tiny crack on that board do this, sounds like blue is dropping out.
Mitsubishi... | Answered on Dec 22, 2012
I would Go Component instead if possible---there are adaptors for the HDMI but you are likely to have issues that way as well.
Mitsubishi... | Answered on Dec 03, 2012
A few things you could and should try, try something on a different input if you are using the coax connection just to know if problem exists that way, could be a bad tuner but that can be got around, also if on all inputs the set does have a hard reset that requires the Mitsubishi remote and a four digit code to enter the hidden option menu.
check the other inputs first please and let me know.
Mitsubishi... | Answered on Aug 28, 2012
You need to turn down the voltage on all 3 crt's. You have a red one, a blue one and a green one. Slowly adjust the knob down until you don't see the shadow any more. Then adjust your color in the user menu.
Mitsubishi... | Answered on Aug 23, 2012
If you contact Mitsubishi the set has three hidden menus---convergence adjust, circuit adjust and OPTION MENU.
Each model uses a four digit code with menu and for example 4750 and in the Option menu is the option to do the hard reset for the set---
The wipes all labels (dvd etc) and puts set back to default on all factory settings.
You might find it if you GOOGLE THE MODEL NUMBER with option menu after it...........
Mitsubishi... | Answered on Mar 19, 2012
does it look anything like these photos?
SD TECH
Mitsubishi... | Answered on Sep 25, 2011
Mitsubishi WS-65611 65" Rear Projection Television Logo
113 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
ws 65611 color shadows
  • Televison & Video
