First, before we proffer any solution, we need to know the problem.
Before the battery drains, does the phone gets hot in any way?
If your phone gets hot, then maybe the problem is from the phone board.
But if your phone does not gets hot before battery drains, then it is obvious that the fault is from your phone battery.
The solution therefore is for you to change your battery to an original one. The same problem might persist if you don't purchase a good battery, please take note.
Hmmm just found solution to the cine dash volume control problem.
You need to shut your laptop down.
Remove the battery for 10 secs.
Replace battery.
Boot up and all should be okay.
I have tried this on mine and it worked fine. If this does not work straight away someone else said something about LaunchManager but I didn't have to do that so can't give any info on that.
You have what's known as a "Parasitic Battery Drain". This is a condition where voltage leaves the battery when the vehicle is off and the key is out of the ignition. The test and solution is too long to post here."Google Parasitic Battery Drain" and you'll find countless sites that offer the test and solution.
