How to Fix UNMOUNTABLE_BOOT_VOLUME Blue Screen of Death
Please visit this website for Instructions on how to.
please rate and hope it helps you.
In these circumstanecs mostly recovery needs to be initiated and as you have tried the advance boot menu optios there are couple of steps that you can try if it works .Turn the computer off and then disconnect all the external devices along with the internet cable .You shoud have only 4 things connected to the computer,the mouse ,keyboard ,power cable and vga that is the cable for the monitor .Please make sure that as soon as you press the power button to turn the computer on start tapping the f10 key repeatedly then you should get the system recovery page .Follow the on screen insruction and when you get to a screen that has advance menu then press alt and then D on the keyboard , a command prompt window opens up then you need to type chkdsk space /r then enter .So when the computer restarts it will try to repair the computer if this does not work then do the same thing to boot the computer to the system recovery page then click on the advance option ?then select distructive recovery ?next then the computer will be formated the recovery will start and once it reaches 100% the computer needs to be restarted and then follow the basic setup for the computer and everything would work normally .In case the recovery page does not load up then you can place an order for the recovery cds from COMPUTER SURGEONS ,they deal with selling recovery disks and their phone number is 1800-496-6127...
all the best.....
