Plug the memory stick into the computer and format it. Unplug it then plug it back into the computer, you should have a pop up that asks you what you want to do (open folder view, play and a few other options), you weant to choose Open a Folder View.
You should now have a window open that you can put files into, if not then go to "My Computer" and select it from the available drives.
Now open up the folder with your pictures in it and select all the pictures you want to transfer then press "copy". Go to the memory sticks folder and right click and select "paste" from the right click menu or hit "CTRL+V".
You will get a progress pop up that shows how long the file transfer will take, after it is done...so are you.
If the memory stick is not recognized when plugged in, you way need to load the software that came with the memory stick for its drivers.
Just put the stick in & open where you have your pics stored & either left click on a pic to highlight it, then right click choose "select all" ,then right click again on any pic & choose "copy". Then simply explore "my computer" left click on the stick & choose "paste". Or you can do this pic by pic if you don't want them all.
