Please clarify: from where to where did you transfer and you wish to transfer? Are you using a USB cable from the camera to the computer? Do you mean the memory card that fits inside the camera?
If you mean transfer photos from the camera via the computer to a memory stick, then the problem may be solved in two steps: First download the photos to your computer. Then from the computer to the stick.
SOURCE: transfering pictures from my memory card
when you connect your camera to the PC.
look in My computer and find the drive ( camera ) probably shows as Drive F:/ G:/ H:/ I:/ or similar.
Right click and open, then copy to folder on desktop, named My-Pictures ( Or similar ) once you,ve copied your photos from memory card to desktop on PC. Format the memory-card. which will erase all data. ( Right Click Format )
This should solve your problem.
Mike @ compurepair.
SOURCE: How to do I transfer pictures from my internal memory to my memory stick?
You would have to click home, and then go to the memory tools and click copy. That should work.
SOURCE: transfer images to memory stick from internal memory
Please insert memory stick in camera, power it up and press Menu >> Copy >> OK
That will copy internal memory pictures to memory stick.
SOURCE: converting internal memory to memory stick
Put memory stick in camera, power up, press Menu >> Copy >> OK
That will copy internal memory pictures on memory stick.
SOURCE: how to transfer pictures from internal memory to
Make sure a card is installed. In any still or video mode, press the Menu button. Press up/down to highlight Image Storage then press the OK button. Press up/down to highlight Internal Memory then press the OK button. (You'll need to set this to Auto later if you want pictures to go to a memory card instead of the internal memory.) Press the Review button, then the Menu button. Press up/down to select Copy>> then press the OK button. Press up/down to highlight what you want then press OK.
