Make sure u don't have the tv set to the video output that the game does not support...with that said u could try this.. under settings>display setting>video output setting> if u have it connected with an hdmi (i'll go with this one) click on hdmi and choose custom. on the next screen u can try selecting the video output that u want to play it in... the 480p choice will always be highligted. hope this helps
SOURCE: some games show that
You should try resetting your video settings.
To do this, turn off your PS3. Then press the power button to turn it back on again, but hold it for a few seconds. The console should beep, at which point you can release the power button.
Then you can re-setup your Display settings (navigate to XMB (main menu) > Settings > Display Settings > Video Output Settings). Choose whichever settings are compatible with your TV/Projector. (if using HDMI, you should probably always use Automatic; it knows what it's doing most of the time).
For a more in-depth explanation, the Sony PS3 website has a pretty good guide found here.
SOURCE: ps3 video settings
I've found confirmation that this problem will be fixed by buying an HD TV. http://www.joystiq.com/2007/05/07/ps3-is-region-free-but-theres-a-hi-def-catch/
SOURCE: When trying to play a game my playstation sias:
why not plug your ps3 to your HDTV with the HDMI cable? It will without a doubt work
