IM NOT EXACTLY SURE OF THE MODEL # BUT IT BEGINS WITH FWS. AFTER WORKING FINE ONE DAY IT WOULD NOT SPIN OR AGITATE. I THOUGHT IT MIGHT BE A BELT OR A COUPLING. WHAT DO YOU THINK?
Hello James, thank you for your post!
I understand that your Frigidaire washer will start to agitate and no water will enter the drum. This could be an issue with your water valve or the control panel. I would check to make sure the water lines are opened and the connections are not restricted or damaged. If the water hoses are not damaged you may need to have a professional technician out to perform a proper diagnosis. This will help you to avoid any unnecessary part purchases. Good luck! -Matt
Hello Joe, thank you for your inquiry!
From what you have described your Frigidaire washer will not drain or spin. I would recommend checking on the drain hose to make sure it is not restricted or too long. Also check to make sure your drain hose is not too far down your drain pipe. If the drain hose is in good condition it might be a possible problem with your timer or drain pump. Since it could any one of those underlying issues I would recommend having a professional technician out. This will help you avoid any unnecessary part purchases. -Matt
