Question about Frigidaire GLTF2940ES Front Load Washer
Fabric softener dispenser
Frigidaire front loader - All compartments of the despenser fill with water at the beginning of the wash cycle, which dumps the fabric softener at the beginning of the wash cycle. We had a "certified" Frigidaire repair person come out who had no clue. He called Frigidaire Tech Support who stated we were adding too much fabric softener. So we added less and it still adds the fabric softener at the beginning of the wash cycle. We tried called Frigidaire Tech Support and they said they will only speak to "certified repairman" and to get a second opinion. ?????
Posted by GaryK_FL on
  • 4 more comments
  • FL_Darlene Nov 16, 2007
    I just posted about the smelly water, but I have had this problem almost from day one. I am trying to figure out how to clean it, and how to make it drain properly. Usually, I just scrape it out, and I use a small brush to try to clear the holes in the top of the dispenser area. What a pain! This was a product I had wanted for a very long time, and now, I am just disgusted!
  • sonnen69 Dec 10, 2007
    I have this same issue. It seems I had this issue when I first purchased my machine a few years ago and ended up having the main computer board replaced. Luckily it was under warranty--very expensive. I again have the same problem and have cleaned everything i can with no better results. Don't think it is an issue where the water is going, but why it does not drain. I have pulled my top cover and did not help.
    Hope there is a solution found.
  • Anonymous Apr 10, 2008
    Mine is doing the same thing - the fabric softener just sits there in a pool - never drains. The suggestion of taking the washer top off and checking a spring - uh I'm not sure what I would be checking it for If I did this, would it likely need cleaning. replacing, reattaching?
  • nemesys Apr 16, 2008
    I have the same problem and cannot find a solution :-(
  • Anonymous Mar 24, 2014
    softener won't dispense
  • Anonymous Mar 26, 2014
    fabric softener is dispensed but not effect on cloth
Anonymous
    Champion:
  • 249 Answers
Remove top of machine, there is a arm running across from programe dail, to drawer despenser,its spring loaded it determines which compartment the water gos into,check it
Posted on Nov 25, 2007
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Front loader. Why doesn't fabric softener dispenser empty?
It can be two things. First, what is left in the dispenser? If its the fabric softener, then the water valve may be faulty. The water valve will have multiple feeds and the fabric softener might be bad. If its a combination of water and softener, then the dispenser might be clogged. You can remove the slide out tray and clean it. Look for build up of fabric softener that might be there. Good Luck?
Nov 23, 2015 | Frigidaire Washing Machines
How do I get the bleach dispenser to drain?
Hello Denise C - There are several things that could cause the bleach to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is bleach? If it is pure bleach, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the bleach dispenser with water. The bleach dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the bleach solenoid is energized and water flows into the bleach dispenser cup. When the cup is full the water siphons out and bleach and water flow into the tub.
If the liquid in the bleach dispenser is pure bleach you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the bleach solenoid and a volt meter is required.
If the liquid in the bleach dispenser is water you probably need to clean the dispenser cup. Scum will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the bleach and overflow the dispenser cup and run into the tub.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the bleach compartment. When the water level goes above the maximum line stop pouring. The water should all drain out. You may also test the fabric softener compartment the same way.
I do hope this information proves to be helpful.
Jan 01, 2013 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener dispenser fills up with clear water after washing cycle is complete. I do not use fabric softener .
Purchase some fabric softener and place it in its normal location at the beginning of the cycle. At the end of the cycle check to see if fabric softener has been dispensed and whether there is water in the cup.
If the fabric softener is gone, but there is water in the fabric softener cup, then your problem may be with the water valve assembly. The water valve assembly (as one complete unit) has a separate solenoid for hot and cold water temperatures, bleach and fabric softener. The fabric softener solenoid on the water valve assembly could be defective (allowing water to fill the fabric softener cup).
Contact an appliance service company.
Feb 17, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
The detergent dispenser want despense the fabric softner
Hello. This is a common problem due to the fact that fabric softener collects in the dispenser and gums it up. Begin with an empty washing machine. Add two cups of vinegar to the fabric softener dispenser and then run the machine on the maximum water and hottest water setting. Once the cycle is complete check it out. It will be as clean as a new machine. If this treatment didn't completely clean out the dispenser, repeat the cleaning a second time with two more cups of vinegar. regards, Joe
ps - kindly rate my answer as helpful. Thanks.
Feb 10, 2010 | Washing Machines
Fabric softner compartment won't dispense during wash cycle
Fabric softener is to slow mix with rinse water in the rinse cycle... check the cold water supply line for a clogged screen or a clogged dispenser box cover... hope it helps
Sep 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Water left in fabrish softener dispenser after wash cycle
My Frigidaire front loader was doing the same thing and also not taking the bleach. I could hear that the water pressure was not real strong when I turned the machine on. I removed the two small screens on the back of the machine where the water supply hoses attached, found they were partially clogged and cleaned them well. The bleach and softener dispensers are now working like new.
Aug 03, 2009 | Bosch Washing Machines
Water goes thru fabric softener dispenser not soap dispenser!
Yes you will need a service call, you may have a issue with the water valve or control, At the start of the cycle it should not be filling the softener dispenser till later in the program.
Jan 10, 2009 | Kenmore 42822 Front Load Washer
Dispenser issues
pull drawer out towards you, untill it comes to a stop.!push down plastic tab and pull the rest of the way out,some dispensers have to be lifted and pulled at the same time.wash it then with hot water! take apart softener compartment to clean,makeing sure small hole is free!!!close eire
Dec 15, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
747 people viewed this question
Top Frigidaire Washing Machines Experts
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Nathan Van Boven
Nathan Van Boven
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
