Both the pink diamond ink and red square in are full and yet all my pictures for the past few days have been very yellow and green. When I clean my print heads it prints a page and at the bottom I have a blue rectangle, a blank spot, yellow, blue, green and finally yellow. I have tried changing the color profiles and advanced settings. Nothing gives me even a hint of pink.
SOURCE: a pink line is on every page printed
This is a very common problem with this model printer, it is caused by toner on the scanner mirrors. You need to clean the scanner assembly unfortunately it isn't very easy to dissemble the printer to get to it.
SOURCE: Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
SOURCE: Blank Ink not pumping to print head
Turn off the device after removing the printhead
After removing the printhead, turn off the device, wait about 20 seconds, and turn it on again without the printhead installed. After it has restarted, reinsert the printhead.
it will go through this long routine of perhaps 20 min or so. after its compleate it should print great.
SOURCE: Printer won't print in black ink.
Plunger needs to be cleaned, print head also would need to be looked at on this one.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: my hp deskjet 1280 will not print yellow
Hello, this is Harry from www.BusinessSpread.co.uk.
We had the exact same problem when printing, we used 3 different 78 colour ink cartages and they all said 100% full but did not work. We then had a look at the dates on the box and they were all expired so when buying ink from anywhere even PC world or Curry’s always look at the expiry date.
Today I went to PC world and purchased a new 78 ink which said expires July 2011 and it works perfectly fine.
Regards,
Businessspread.co.uk
