Question about Epson Stylus Photo R220 InkJet Printer
When I Print the color Yellow, it's being printed as Pink.
Posted by donald_abeno on
Erna Leenaars
    New Friend:
  • 87 Answers
I think you switched the ink stations. Try to switch the yellow and magenta. It also is a possibility that they are refilled with the wrong ink color. Place new ink cartridges and your problem is solved! (It can be that a few prints still show some pink color, because there is a residu of magenta in the yellow printhead)
Posted on Jul 07, 2011
Yellow ink will not print
You may have blocked yellow print head nozzles.
Try the printer maintenance to clear the printer nozzles.
After several deep cleaning attempts and there is no improvements in the printthen a new print head is required.
A new print head maybe expensive and it maybe more cost effective to purchase anew printer.
The Print head will contain all the nozzels for all the different colors so you cannot just replace a single color print head nozzels.
May 22, 2012 | Canon Office Equipment & Supplies
Im using hp deskjet 2660 cartridge says INTRODUCTORY HP TRICOLOR PRINT CARTRIDGE (colors) cyan magenta yellow 60 it's not producing yellow images that i printed are in pink or purple i...
This model printer has only two slots for ink cartridges. One is for a black ink cartrigde and the other is for a tri-color cartridge which contains cyan, magenta and yellow inks.
This tri-color cartridge has run out of yellow ink, you need to replace this tri-color cartridge.
Aug 12, 2011 | Office Equipment & Supplies
My colour is coming out pink- when I see yellow and green on my screen it prints pink and blue
You need to replace ink, try to buy complete set of ink and replace it, if same problem in printing, try run self test print if default test page print in complete color, or else there’s problem with your print head.
Mar 23, 2010 | Epson AcuLaser C4000 Printer
Color printing comes out pink
Sounds like a bad color cartridge. It is missing yellow.
Dec 04, 2009 | HP OfficeJet D135 All-In-One InkJet...
Printer won't print yellow
Either theyellow is finished or the nozzles are blocked. Try cleaningthe nozzles of the cartridge.
May 26, 2009 | HP PSC 2175 All-In-One InkJet Printer
Printer will only print in purple/pink,enstalled new colour cartridge configured as required,still no change. help thank you
Print out a calibration sheet, either from the menu, or press photo and cancel at the same time. Your calibration sheet is probably missing a color. You should have black, blue, yellow, and magenta(pink). If you're missing any of these colors, your printhead is clogged. Try doing a printhead cleaning. Print another calibration sheet, if the color is still missing, you need a new printhead. Call Kodak.
Sep 30, 2008 | Kodak EASYSHARE 5300 All-In-One InkJet...
PROBLEMS WITH COLOR NOT PRINTING
pictures are coming out with a green tint
Aug 01, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Canon MP510 not printing correct colors; will not print yellow and will only print purple, pink, and blue.
Refill the yellow section of your cartridge. The yellow exit part of the cartridge head could be blocked as well. Read on Google how to unblock clogged nozzles.
Apr 04, 2008 | Office Equipment & Supplies
Epson Stylus Photo R220 InkJet Printer Logo
267 people viewed this question
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
