More than likely your charger is broken. If the charger has any lights on it, see if they turn on when the charger is plugged into an outlet. If the lights don't turn on, try another outlet. If the lights still won't come on, you need a new charger.
If the lights work, or your charger doesn't have any try using a different charger and see if the PSP will charge. If not, then the actual connection within your PSP is shot, or there was a short in your system.
replace the battery as it may be out of CYCLES even tho it says its fully charged if the battry is new your going to need a new element inside usually this consist of a new logic board under the battery pack.
Remove the battery. Plug the PSP charger into the PSP. Turn it on.
The PSP works with no battery inside. If you're not getting a green light at all, your PSP has some sort of damaged as it should work while plugged in with no battery inside.
u cant charge on a computer unless you have a charger that hooks up to it...are you sure your using a charger or are you using the cord that transfers data to ur psp! the data cord will not charge ur psp its not a charger all it does is transfer data sorry you need a charger for the psp not a data cable
You don't have a problem; the seller is an idiot. Leave it plugged in for good measure, but your PSP is fine.
Many products ship with a completely discharged battery (many cellphones, for instance) and they must charge for a long time. PSPs don't; they ship with a partially charged battery.
