My tv turns on for a few moments and then goes off
These sets rarely shut down from dust. Chances are that the Temp sensor has failed. It is located on top of the lamp housing on the Light Engine. To test this you must locate the temp sensor and short with a test lead or wire across the two terminals and make sure the interlock switch is held in the up position, then turn on the set and see what happens. If the set stays on then the temp sensor is bad. If the set still shuts down then and goes straight to "Stand By" the you have a bad power supply. Make sure you have a good Lamp installed as this can cause the same symptom.
