Our tv screen goes black and the sound goes a few seconds later. It's been intermitant. My FEELING...
(More)
Our tv screen goes black and the sound goes a few seconds later. It's been intermitant. My FEELING is its heat related. The 2 green lights will flash and the red light stays solidwhen it goes off.Looks like a EVIL FACE! Sometimes it will restart after a while, and then go back out. I've replaced the color wheel myself already. The screen color and brightness seem fine. I've tried a fan at different places around the back with no dfference. Is there a way to access a menu and see preformance for the internal fans?
the picture on my 4 plus yr old hlp5063w shuts off and then comes back on on a regular basis. The...
(More)
the picture on my 4 plus yr old hlp5063w shuts off and then comes back on on a regular basis. The sound usually stays on
How do i change my picture to normal mode? I can only get the component 2 source and only the wide...
(More)
How do i change my picture to normal mode? I can only get the component 2 source and only the wide screen and 4:3 pictures are options. Neither of these 2 pictures enables me to see the graphics when i am watching a football or baseball game. I need a screen that will allow me to see everything that is broadcast.
Try first leaving the TV power cord unplugged for some times, let say one hour or so. Also
ensure that the fault is not coming from a faulty receiver...
written by ginko
FL231. FUSE.... The RCA ITC22 chasis has a common problem. and it not all that difficult to repair. Does your rca projection tv have read blue and...
written by willtab
Here are some of the most common symptoms and example pictures for projection TV convergence problems. This is a very common failure on Projection TV...
written by Ecollier2012
Here are some of the most common symptoms and example photos of a convergence problem. This is a very common failure on Projection TV sets. Screen...
Your TV may have a convergence problem. Here are some of the most common symptoms. Screen looks 3D One or more colors can't be adjusted when using the...
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
Call 1-800-447-1700 Consumer Electronics Technical Dept. GE sold out to: Thomson, Inc. P.O. Box 671988 Marietta, GA 30006-0034 I called this company...
written by jrleopards
I received a full refund for this tv, Monday Oct 6, 2008. Thomson had a courier pick up this tv at my home 2 weeks ago. Just call the numbers I have...
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
