Tony,
From what you're describing it sounds like ring-cracked solder joints or maybe a couple of failed caps. What's the model number???
Ring cracks happen because a component on the board gets hot and cools many thousands of times over the life of the Tv and the extreme heat causes the solder to crystal and break leaving the smallest of rings around where the coponent would otherwise firmly be soldered, breaking contact with the board. The other possibility is one or more electrolytic capacitors measure high equivilent series resistance and take more time (thus heat) to reach an operating temp sufficient to dissipate voltage at a correct rate.
Drop me a post and let me know what the model number is and I can look it up for common problems in the schematics and service manual.
Bill
BTW: Uk is a bit beyond my normal servicing route... :)
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
[email protected]
By the way its a casio TV-430 LCD, very small. pocket size nd runs off 4 x AA batteries totalling 6 volts
me too. When i turn it on, the screen turns green, and in the background their is a faint squeeking noise.
