Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
Posted on Mar 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Tv freezes white and black negative image
TV works for about 30mins and then freezes in a black and white negative image. I can not turn off unless I unplug the tv. It will start back up and work for a short period of time. I just replaced the bulb and it seem to work for two days. Please advise...reading the forums it sounds like I have an issue with the degital board?
  • 7 more comments
  • shifty123 Apr 08, 2008
    I have the HLN507W which is basically the same TV. I am having the exact same problem. Not under warranty. New lamp does not fix it either. How does a digital board go bad if you have an expensive surge protector?
  • Days-late May 14, 2008
    My HLN5065W started freezing after a short time of being on. This started one week after the warranty expired. I am an electronics tech and could work on it myself if I had schematics. If not I would like to be sure I have the correct part number for the board so I can replace it. Maybe I can do a visual check to see where the small charge went off to take it out right after the warranty expired.
    HYLN5065WX/XAA ser# 36553CEX30096
    Any assistance would be greatly appreciated, it has been a great TV and we would like to fix it for less than the cost of a new TV.
  • ablochtein Jun 28, 2008
    I have the same problem..... Please help me.
    SVC Model: HLN5065WX/XAA, Serial Number 36553CEWC01756V.
  • anglemarzett Jul 08, 2008
    I have changed the color wheel and now i am having the same problem where the tv plays for awhile and turns to a black and white negative image then the picture goes out but volume still on and i have to unplug it to turn it off
  • SkiDude69 Jul 15, 2008
    I have the same issue with the black and white freeze up mine is a HLN5065WX/XAA can you get me the part and possibly a price / place to purchase it?
  • jolane220 Oct 24, 2008
    We replaced our dlp bulb and it too didn't work. Still turns off after a short time and off and on we get that negative white/black image pixel thing as well. We have a VIVITEK RP56HD22A Serial # M638JHCK01405
    Would like some help as well!
  • bearclawjj Nov 03, 2008
    Have the same issue on my HLN-4365W DLP. Warranty ended April 08 ( 4 year from 04) Happened in October along with color wheel replacement. Best Buy gave me the finger on any help. So will not be giving their stock any help going forward. Went to Cosco got a 47" LCD for 1100. DMD board for Samsung(the problem) cost 937.00....what a joke.. Original Best Buy purchase was 3500 including stand and warranty...
  • evankyla May 11, 2010
    I have the same problem. Please let me know anything that take care of the problem or what it may be.
  • Anonymous Mar 23, 2014
    seems to be temp related, screen pixalates and freezes in black and white, remote won't work, have to unplug to restart.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 30, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1440
Points
Remove back cover (14 screws)
As viewed from back, Right side, small fan
Clean fan, blow out lint between components.
Problem is over heating caused by fan not supplying enough air.
Problem solved
Component causing problem should have a added heat sink, to improve cooling.
Mfg should have a corrective action on this problem and defining component.
A
Anonymous
The model is a hln5065w version 1, bk50l2...if that helps
Robert Johnson
Level 2:
Sergeant:
  • Expert 395 Answers
  • Posted on Mar 18, 2008
Robert Johnson
Expert
Level 2:
Sergeant:
Answers
395
Questions
0
Helped
152001
Points
887
Replace the DMD modual. part # BP96-00249A
Anonymous
Level 3:
President:
  • Master 1,284 Answers
Anonymous
Master
Level 3:
President:
Answers
1284
Questions
Helped
498752
Points
3271
Yes the digital board is the culprit. I need the complete model number so I can get you the correct part number. On the right hand side of the TV is a sticker with the model/serial and sometimes a version number. Get me all those and I will look up the part number.
2answers
Soniq QSP420T/2 42'' integrated Plasma TV
What is the problem you faces with this set? Try this link.
While streaming Netflix from my laptop (via S cable) to my RCA TV, the image on the TV is black & white. Whether streaming or not, when I hook up my laptop to the TV, the desktop image on my laptop...
If the cable is damaged then one of the pins can be bent inside or if it unscrews a solder connection may be undone. see the photo showing color on the left and bw on the right. Also plug everything in turn off everything then turn on the computer and then turn on tv. also try just opposite turn on tv and reboot computer.
Go to Bing homepage Video Wikipedia SVIDEO TV BLACK AND WHITE SCREEN Graphics Cards
Lately the tv displays a b&w negative image instead of color. Unplugging and replugging the TiVo T800 (and waiting for the reboot) fixes the problem for awhile. Any ideas?
Strange. Are you sure it's the TiVo at fault? I'm thinking when you turn off the unit and back on again you're actually forcing your TV/Monitor into the correct input. When it next goes into black and white, try selecting different TV AV inputs, normally a square or circle with an arrow in it on the remote control.
If this fixes it, I'd suggest that you have another piece of equipment connected to your TV that's fighting for control.
1helpful
TV screen went negative. Brand new TV
I would use the warranty for this problem. The part that need to be replaced can be somewhat expensive.
With the credit card statement, you can use that as a receipt.
1helpful
Negative image and then black and won't turn off!
The negative image on the screen is the DMD board (Digital Mirror Board). The cycle sound is the color wheel trying to spin but if the DMD board is going bad, it will effect the color wheel and not spin. There for your image will freeze.
Picture freezes Black/White
It's most likely the digital board, Samsung p/n# Bp94-00385a but I'd trace test both the digital and analog first before blindly replacing it - too costly to just guess..
Bill
3answers
TV won't shut off
Sounds like color wheel BP96-00250A. Have installed by professional $350 ish
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
