I bought Dynex DX-LCD37 TV last March. Now it show picture but no sound. I click Audio in Remoter,...
(More)
I bought Dynex DX-LCD37 TV last March. Now it show picture but no sound. I click Audio in Remoter, TV screen show a red circle. What is broken?
DX-LCD37, continually switches between 3 & 14. If turned off, it may stop for a few minutes,...
(More)
DX-LCD37, continually switches between 3 & 14. If turned off, it may stop for a few minutes, then start again.
Dynex 36 inch flat screen TV automatically switches between channel 3 & 14 when turned on. I...
(More)
Dynex 36 inch flat screen TV automatically switches between channel 3 & 14 when turned on. I turn it off, then back on, sometimes it will stabilize, and 3 minutes later will start doing it again
having trouble hooking up dvd player need to know where all the wires go we also have direct tv. can...
(More)
having trouble hooking up dvd player need to know where all the wires go we also have direct tv. can you please assist us. thanks
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
