composite video cord.
it only hooks via hdmi cable so can't hook it up unless you can find a
HDMI to Composite Converter Adapter
google it.
hope this helps
Check whether the output taken from from the Vocopro is from video/audio out. By mistake, if you had connected the RCA cable to the 'input', you won't get any audio or video and also stand a chance to damage both the devices, as video in/out is a very sensitive line.
hi that"s easy thing. first connect rca wire red white yellow to dvd hook up same colour red white & yellow female rca connection. then use another rca wire connect to your tv be video input in yellow one . red & white be sound input - red to red . white to white. just that. good luck!!
Most TVs have a yellow video and a white audio and red audio input. The Wii comes with a cable to connect to a TV with a yellow, white and red RCA cable. Plug in the large block end of this cable to the Wii (rectangle block) and the other end into the TV using the yellow plug to the yellow input jack and the white plug to the white input jack and red to red. Select on the TV using the TV remote, the input where the Wii is hooked up. This is the standard way.
If you have an older VCR, you can connect the cable to the vcr "in" , then connect the A/Vcables from the video and audio out of the vcr to the A/V on the set and put the set on av1 for source. If you don't have a vcr then you will have to get a box.
Red = right sound channel, white = left sound channel and yellow = video (picture) channel. if you have the connections matching these on the tv, then there should be an AV channel on the remote/tv control panel. Select this channel to view, if more than one AV channel on the tv, there will be a number next to the sockets you plugged into. Select the AV number and away you go. If your tv doesn't have the correct sockets you can buy a converter to use the ariel socket on the tv.
#yellow cord in yellow socket #red cord in red socket #white cord in withe socket
now power the dvd
#Yellow cord in yellow socket there will be 2 places for the red and white cords #the red and white cords must be inserted in the audio, # you will see them next 2 each other insert them you it will work. For More Info Email To [email protected]
If your hooking it directly to the tv depending on how old the tv is use one of the inputs. Hook the two red and white to red and white and the yellow to the video in input. If it's an older tv you will need whats called an rhf adapter. Hook your color codes together and use a cable cord to go from the antenna out to the tv's uhf input. I hope this information was helpful........... : )
buy a new rca cable or RF cable for you're cable box ,then connect the output of dvd red/white/yellow to the tv video input red/white/ yellow and for you're cable box connect the RF cable to tv ant.
