I have the logitech MX3200 wireless keyboard. I have changed the batteries and several keys on the keyboard are not responding. Some have a delayed response time and after I have touched them several times with no response there will suddenly be several of that character appear on the screen. I have also moved the receiver to a better location, but no change.
This post seems to be a duplicate of one posted under the name of Guest, so, I am pasting the solution here just in case you have not gotten notification of resolution suggestions.
Your problem sounds more like the system running slow rather than the
keyboard being the issue.
Do routine maintenance and cleanup on your
system to see if it helps it.
To start the Disk Cleanup tool and
specify the hard disk to clean by
using
a command line, use the following steps:
Then check your
system for malicious software.
cleanmgr
These things should help
if this is the cause.
Let me know if this resolves your issue.
