We are using the logitech mx3200 wireless keyboard attached to a laptop. We have an overhead projector which, without the wireless, we use th blue fn key and toggle f8 key to get display on projector and laptop screen. When I am using the wireless keyboard, what is the equivalent combination?
Likely also the Fn key and F8, if not the keyboard may not support that function. Regardless you can change the active displays in any way you want through the OS, use your windows key and type "display".
Should be the same thing. Laptop is just sending commands to laptop which is already connected to the projector.
Otherwise try contacting Logitech directly here: http://support.logitech.com/contact
SOURCE: Logitech MX3200 wireless keyboard & mouse
I hope this helps.Go to the link scroll down to the end of the page and click on the link named Blue tooth mouse or keyboard not working properly..
http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=535&p_created=1087233447&p_sid=RNUu3HOi&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MywzJnBfcHJvZHM9MCZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfcGFnZT0xJnBfc2VhcmNoX3RleHQ9dHVybiBvbiBMb2dpdGVjaCBNWDMyMDA*&p_li=&p_topview=1
This should give you the complete info about it..If you dont understand something comeback and ask here..
SOURCE: MX 3200 Cordless Laser Keyboard - Logitech
Press the FN key and *at the same time* press the F10 key for 1 second.
The first part of the time should start to flash.
Use the up / down keys to change the hour, then press TAB. The minute figs. should now flash. Use up/down to change the minutes and press TAB.. do the same with the date and month etc, you can also set 12h or 24h clock.
When you are finished press ENTER.
SOURCE: deactivate the zoom function on logitech mx3200 keyboard
This should help you out:
FN + pics key will mute sound for the slider on the MX 3200
FN + 'x' (close) key will disable the zoom slider and the 100% key
FN + document flip key will re-enable them
SOURCE: Need instructions for change time on Logitech MX3200 wireless keyboard
To adjust the LCD's time and date:
The time and date on the LCD should now be displayed properly.
SOURCE: Logitech MX3200 Wireless keyboard works but mouse does not
i have the same wireless keyboard. i suggest that u redothe setup process and setup the mouse first. if the problem persist then move the wireless scanner.
