I have the logitech MX3200 wireless keyboard. I have changed the batteries and several keys on the keyboard are not responding. Some have a delayed response time and after I have touched them several times with no response there will suddenly be several of that character appear on the screen. I have also moved the receiver to a better location but no change.
Your problem sounds more like the system running slow rather than the keyboard being the issue.
Do routine maintenance and cleanup on your system to see if it helps it.
To start the Disk Cleanup tool and specify the hard disk to clean by
using
a command line, use the following steps:
Then check your system for malicious software.
cleanmgr
These things should help if this is the cause.
If your problem still is present, change the battery in the keyboard. A battery that is close to empty will cause this as well.
Let me know if this resolves your issue.
