Dell Inspiron 6000 Notebook Logo
Anonymous Posted on Mar 24, 2010
Dell 6000 power problem? - Dell Inspiron 6000 Notebook
  • Anonymous Mar 25, 2010
    XXCHEMLIGHT,
    I have a Dell Inspirion 6000, the battery is on a recall status and I am getting a replacement sent to me in ( 20 days ), here is a better explanation of the problem I am having!
    There are noted problems on this computer, Power Button, Battery Jack main board problems and the battery recall.
    Symptoms? are; the power supply shuts down when plugged in with or without the battery installed.
    Dell is sending me a replacement battery in around 20 days. However, I do not think this will resolve the problem?
    I think that the defective battery damaged something or the noted problems listed above is what happened!
    I have not disassembled the computer to see if it could be a power button problem or if the contacts on the mother board are bad!
    Thank you for your reply and request for more information! Hopefully you can shed some light to me on this problem?
    One more question, what opinion do you have on FixYa?
    Leonard Roberts
    [email protected]
  • Anonymous May 11, 2010
    need more info exactly what is your power issue.
Anonymous
Level 1:
Guru:
  • Contributor 29 Answers
  • Posted on Apr 12, 2010
Anonymous
Contributor
Level 1:
Guru:
Answers
29
Questions
0
Helped
14146
Points
39
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source is a battery. If the battery indicator flashes amber or is a steady amber, the battery needs to be charged. If the battery is flashing green and amber, the battery may be defective. To troubleshoot this problem, use the following procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer operates normally when using AC power, go to step 7. If the computer does not boot when using the AC adapter, see the previous subsection, "Total Power Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Your computer may be in a hot environment. Charging the battery in this condition may affect the life span of the battery.
Yes. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective. Call Dell for a replacement. (See Chapter 5, "Getting Help," for
instructions.)
No. Call Dell for technical assistance. (See Chapter 5, "Getting Help," for instructions.)
i know one professional online battery shop (http://www.global-battery.co.uk )specially in supplying dell replacement battery.Fast Shipping.and Usually ships the same business day!
you can buy Dell Inspirion 6000 battery very easily here
there are also many other dell batteries on sale.
Dell xps m1530 Battery
Dell Inspiron 2650 Battery
Dell inspiron 8600 Battery
you can buy high-quality dell laptop batteries in US online shop
http://www.sales-batteries.com
Anonymous
Level 3:
  • Master 3,940 Answers
  • Posted on Mar 26, 2010
Anonymous
Master
Level 3:
Answers
3940
Questions
0
Helped
1405407
Points
12062
Troubleshooting a power problem is fairly simple:
1 Try a different AC adapter, see if there is any change 2 If system will not power on with a known good or new AC adapter, then the power connection on the motherboard is likely damaged and the motherboard will need to be replaced.
Where can I download an owner's manual?
Inspiron 6000 Service Manual - Product Support ' Dell US
www.dell.com/support/home/us/en/19/.../inspiron-6000/manuals
DellManuals & documentation for your Inspiron 6000. Last Revised: 7/8/2013. Manuals.Inspiron 6000 Owner's Manual PDF (1724 KB). More Languages. Deutsch ...
DELL 6000 OWNER'S MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Dell Manuals > Laptop > 6000
View and Download Dell 6000 owner's manual online. ... Dell owner's manual notebook pc inspiron 6400, e1505 (186 pages) ... NOTE: Corporate, government, and education customers can also use the customized Dell Premier Support ...
Dell Inspiron 6000 turns on but does nothing else.
From the description the hard drive has failed or windows has corrupt files. Unplug power supply from laptop and remove main battery, press and hold power for 2 minutes to remove residual voltage. when finished install battery and power supply now power up.
2answers
Dell Inspiron 6000 (approx 4 years old) has an issue with the power cord internal connection? Battery and Power cord/adapter are fine. Computer constantly switches from battery to AC when powered on. ...
The input jack that is soldered to the motherboard (where the AC jack plugs in) probably has a cold solder joint. Thus the laptop switches from battery to AC power. You can try to have the solder joints
re-soldered.
2helpful
Dell inspiron 6000 battery light is orange
remove the battery and insert again. if it continues then you will have to check the power source perhaps current it not enough for charging, if it continues then you will have to get a new battery
2answers
I need to replace power jack for Dell inspiron
Better to call Dell technical support for this issue. They're the only one that can provide on your issue. Thank you.
Dell Inspiron 6000 - faulty power cable sparked!
there is no fuse to replace. i think it completely burned. need to get service.
1helpful
Sudden shutdown dell inspiron 6000
hi, i have something strange found in my inspiron 6000:
it looses SMD-parts in the dc-power-converter!
...strange isn't it?
maybe are the suddenly shutdowns the beginning of this ****!
you need someone who knows good soldering....
...and maybe someone can tell me which kind of parts the mine d6000 has loosen :oD ?
it came back from dell *without*...!!!
...please can someone post me a foto?...
thanx, lapdoc
3answers
Dell 1691p http://www.cheap-laptop-battery.co.uk/dell-1691p.htm
who gave you that link? you won't get it there, try here for your model:
http://www.cheap-laptop-battery.co.uk/dell-inspiron-6000-battery.htm
regards
2helpful
11answers
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
