Question about Dell Inspiron 6000 Notebook
I need to replace power jack for Dell inspiron
I need a service manual to replace power jack for Dell inspiron 6000
Posted by gtirmizi on
dalepbaker
  • 32 Answers
Http://support.dell.com/support/edocs/systems/ins6000/en/sm/index.htm
Posted on Oct 09, 2009
Anonymous
    Scholar:
  • 98 Answers
Better to call Dell technical support for this issue. They're the only one that can provide on your issue. Thank you.
Where can I download an owner's manual?
Inspiron 6000 Service Manual - Product Support ' Dell US
www.dell.com/support/home/us/en/19/.../inspiron-6000/manuals
DellManuals & documentation for your Inspiron 6000. Last Revised: 7/8/2013. Manuals.Inspiron 6000 Owner's Manual PDF (1724 KB). More Languages. Deutsch ...
DELL 6000 OWNER'S MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Dell Manuals > Laptop > 6000
View and Download Dell 6000 owner's manual online. ... Dell owner's manual notebook pc inspiron 6400, e1505 (186 pages) ... NOTE: Corporate, government, and education customers can also use the customized Dell Premier Support ...
Jan 01, 2016 | Dell Inspiron 6000 Notebook
Tip
Battery won?t charge and AC adaptor not recognized
I have a Dell Inspiron 6000 that just turned two years old.
After one year, my dell 6-cell battery started to falter, so Ipurchased a new 9-cell battery. This worked fine until a couple ofmonths ago when I noticed that my 65W adaptor was frayed. I bought anew 65W Dell Inspiron 6000 ac adapter andit worked well for about a week until I noticed that my battery wasn’tcharging at times. If I was patient, or unplugged the adapter andplugged it back in, the battery began charging and all was saved.
dell-inspiron-6000-laptop-battery.jpg?w=200
This lasted only a short time until my Dell Inspiron 6000 batterywouldn’t charge at all for long periods of time, and sometimes thecomputer wouldn’t turn on, even if plugged into the wall. I thought itmight still be the adaptor, so I borrowed a fully functioning 90W Delladapter from a family member to test the system. This worked better,but still not great.
When I removed the battery and started only fromAC power, the functionality was also intermittent. Usually, if thecomputer actually started, I received the start-up error “The Inspiron 6000 AC AdapterType could not be determined, etc. etc. etc.” After pressing F1, thecomputer booted, but if the battery wasn’t in, the computer didn’tusually last long before shutting off. Unsure if maybe the battery wasthe problem, I put the 6-cell Inspiron 6000 batteryback in, and it too wouldn’t charge, although (together with the 90Wadapter) my computer would at least start more consistently if pluggedin. The error remained however, and sometimes the system stopsrecognizing power and switches to my ever dwindling battery power untilthe adapter is recognized again.
The problem is with the jack on the motherboard inside our Inspiron 6000’s. This is the jack you plug your power plug into on the back of the laptop.
Somehow the jack gets worn and does not make correct contact withthe laptop so the Laptop does not see the power supply as a legit Dellbrand. So the powersupply will not charge the laptop battery and run the laptop at the same time.
DC power jack repair guide. Do-it-yourself instructions.
Modern laptops are all sold with built-in wireless laptop ac adapter.Some power notebooks used by corporate road warriors will have powerfulcellular adapters that connect the laptop to the Internet via the cellphone infrastructure
A bad connection between DC-IN power jack on the system board and the system board is a very common problem with dell pa 12,dell e1505 and Dell Inspiron 6000notebooks. If your laptop is out of warranty, then you can fix theproblem by resoldering DC-IN jack on the system board. If it’s stillunder warranty, it would be fixed at no charge to you. Problem symptoms:
  • Laptop randomly shuts down without any warning.
  • Power LED and battery charge LED start flickering when you wigglethe power cord or the AC adapter tip on the back or your laptop.
  • The battery will not get charged.
  • When you plug ac adapter for laptop, the laptop appears to be dead and there is no LED * activity at all (DC-IN jack on the system board is broken).
To fix the problem, you have to take your laptop apart, remove the system board to resoleder or replace the DC-IN jack. dell pa 12 and Dell Inspiron 6000 disassembly guides will help you to remove the system board. Take a closer look at the power jack on the system laptop board witha magnifying glass. In most cases you get the power problem because ofa bad connection between the DC jack and the system board, you’ll see acrack between the DC jack connector and the system board.
on Jan 22, 2010 | Computers & Internet
I need a manual for a laptop
Search Results
    www.dell.com/support/home/us/en/19/product.../inspiron.../manuals
    DellJul 8, 2013 - Inspiron 6000 Owner's Manual; PDF (1724 KB). More Languages ... Dellis not testing or developing Windows 10 drivers for this product.
Oct 15, 2015 | Dell Inspiron Computers & Internet
Dell Inspiron 6000 (approx 4 years old) has an issue with the power cord internal connection? Battery and Power cord/adapter are fine. Computer constantly switches from battery to AC when powered on. ...
The input jack that is soldered to the motherboard (where the AC jack plugs in) probably has a cold solder joint. Thus the laptop switches from battery to AC power. You can try to have the solder joints
re-soldered.
Jan 04, 2011 | Dell Inspiron 6000 Notebook
Connector not allowing charger to charge battery, loose in back of lap top
This will require either the replacement of the power connection by a competent board repair service or replacement of the motherboard
Example: (Not necessarily a recommendation)
http://comprehensivecomputing.net/79_dollar_power_jack_repair.htm
Motherboard
http://shop.ebay.com/i.html?_nkw=Inspiron+6000+motherboard&_sacat=0&_odkw=Inspiron+6000+power+jack&_osacat=0&_trksid=p3286.c0.m270.l1313
Sep 27, 2010 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 - faulty power cable sparked!
there is no fuse to replace. i think it completely burned. need to get service.
Sep 04, 2009 | Dell Inspiron 6000 Notebook
How do you fix or replace a faulty power jack for inspiron 6000?
I PERSONALLY DONT THINK THAT ANY DRIVER IS GOING TO HELP YOU REPLACE UR POWER JACK,YOU WILL HAVE TO GET TO AN I T SPECIALIST,CAUSE UR JACK WILL HAVE TO BE REPLACED,AND IF YOU TRY AND DO THIS YOU WILL VOID THE WARRANTY ON THE MACHINE
Jul 03, 2009 | Dell Inspiron 6000 Notebook
Directions to replace the display for a Inspriorn 6000
Here's a link to Inspiron 6000 service manual: http://support.dell.com/support/edocs/systems/ins6000/en/sm/index.htm
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Jan 13, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000 power cord connection
Hi
I am afraid it is going to be a a bit of work taking the laptop apart, solder the power jack than put back together.
If you are not confident to doing it i suggest you seek help by having a repair shop/centre service it for you. If the laptop is under warranty, you are better of raising a warranty call.
Anyway, you will need some screw drivers; small Flat and a Philips heads. You will also need soldering iron and lead. Finally, a work table will make things easier.
Check Replacing the System Board for help access the system board. Check and solder yo the power jack carefully and reverse the steps to put the laptop together.
Let me know how you get on.
Mike
May 26, 2008 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
251 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
