Hp 8550n probem printing. Box Message: incompatible print settings. Output bin: Mailbox 3 Accessory output bin not instaled. Box won't close if I check either of the options. Options are: Restore my previous settings. Or Keep this setting and I will change later.
SOURCE: how to clear paper jam in output bin
The printed page comes through the hot fuser at the top of the printer, through the exit rollers an end up in the exit bin.
We cleared a massive paper jam out of the fuser, by removing the grey surround on top of the printer. The plastic hooks that hold it in place get broken in the process, then you will the jammed paper between the fuser rollers, and the exit rollers. A technician can do it for you, but is unessersarly costly.
SOURCE: jam in output bin
Make absolutely sure there actually is no paper jammed in there.
I came to this page with the same warning, convinced I had a software glitch. Turned out there was a page accordion-folded down to the size of a pencil lead. I didn't know paper could be folded that small.
Of course, everyone here may be a lot brighter than I am, in which case sorry to waste your time. But for me, the obvious first fix needed to be thoroughly explored before cursing HP and their machine.
Try taking all of the paper out of the paper tray and try to pull it from the front of the printer.
