Televison & Video Logo
Posted on Mar 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
** picture or sound
EDtv Monitor, LCD TV
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Mar 07, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
52
Points
Anonymous
Level 3:
Genius:
  • Master 3,587 Answers
  • Posted on Mar 09, 2008
Anonymous
Master
Level 3:
Genius:
Answers
3587
Questions
29
Helped
1147440
Points
9064
Model number please?
Sanyo lcd tv 20"has sound but no picture
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks! ! ! !
When I turn it on I get sound but no picture. If I wiggle the on off switch on the monitor I can sometimes get the picture back.
It sounds very much like you have a poor connection within the monitor. It may even be the switch?
Check around the proximity of the switch and hopefully you will see either a poor connector or, what can best be described as, a black ring around a soldered joint causing the problem.
Hope this helps.
Dark and snowy Screen on my Zenith Plasma
Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc.
3answers
I heard a loud pop and the display went out completely. i can still here sound but the picture just isnt there
It sounds like your monitor just went bad. The reason you can still hear sound is because there is nothing wrong with your sound card. You can try connecting the monitor to another computer to see if it works. If it does not, then the monitor has died.
2helpful
2answers
Screen went black
Check the power supply for 12 volts dc, it must provide at minimum 3 amps of power to trigger the on circuit. If not, replace the adapter... if you need one, please contact me.
7helpful
Does my Sanyo CLT1554 15 in. EDTV-Ready LCD have a digital tuner?
Your specs are here, http://reviews.cnet.com/flat-panel-tvs/sanyo-clt1554-15-lcd/4507-6482_7-32013875.html?tag=mncol;psum
unfortunately you have a
  • Analog TV Tuner NTSC
and
  • Enhanced Definition Television (EDTV) Monitor - EDTV Monitor refers to a monitor or display with the following minimum performance attributes:- Display Scanning Format: Has active vertical scanning lines of 480 progressive (480p) or higher- Aspect Ratio: None specified
You need a tv that has this:
Enhanced Definition Television (EDTV) Tuner - EDTV Tuner refers to a RF receiver with the following minimum performance attributes: - Receiver: Receives ATSC terrestrial digital transmissions and decodes all ATSC Table 3 video formats.
So Sorry, the tuner is not Digital.
I dont know if my lcd tv supports 720i, 1080i, or 1080p
Sorry. It does not. 480i and/or 480p.
http://www.generalmanual.com/Televisions/Sanyo-CLT1554-STEREO-LCD-TV-EDTV-Monitor.htm
Picture Resolution: 1024 x 768 (XGA);NTSC (480i) EDTV (480p)
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
