Microsoft Windows XP Media Center Edition 2005 for PC Logo
Posted on Mar 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In my window xp media center I cannot launch the the games but every thing else seem to work ok. what do I do to launch the games in the media center of my windows xp? I had to install updates and even after I install updates the games still does not launch.
Anonymous
Level 2:
  • Expert 87 Answers
  • Posted on Mar 09, 2010
Anonymous
Expert
Level 2:
Answers
87
Questions
0
Helped
30575
Points
218
Might be some error with your graphics
  • Anonymous Mar 09, 2010
    might be some error with your graphics
How to setup xbox 360 windows media centre
Instructions for Windows 7
1. Connecting the console to the network
Press the Guide button on the Xbox controller.
Go to the Settings page and select System Preferences.
Select Network Settings.
Select your wireless network or select Wired network if you are using a wired connection.
Select Test Connection to Xbox Live.
If the network connection status is Connected, go to step 2. Otherwise, select More information on the console and follow the instructions.
2. Delete previous connections (if necessary)
Launch Windows Media Center.
In the bottom section of the menu, click the down arrow and select Settings in the Tasks section.
Select the Media Extender section.
Select Xbox 360 Media Center Extender.
Select Delete.
Press 'Next.
Actions on the console. Delete previous connections
Go to the My Settings page and select System.
Select Computers.
Select Windows Media Center.
Select Disconnect.
Press the B button on the controller to return to the Xbox control panel.
3. Getting the installation key on the console
On the console, go to the Applications page, select My Applications, and then Windows Media Center. Tip. Don\u0027t see the Application item? You might need to update your Xbox 360 console software.
Choose Continue.
Record the 8-digit installation key.
4. Adding a console to Windows Media Center
Launch Windows Media Center on your computer.
Go to the Tasks section and select Add media box.
On the setup screen for the media extension, click Next.
When prompted, enter the 8-digit installation code obtained in step 3.
Click Next to complete the installation.
5. Launch Windows Media Center on the console
Go to the Applications page, select My Applications, and then Windows Media Center. When you first open Windows Media Center on the console, it will take some time to build the media libraries.
Done!
2answers
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
11helpful
2answers
I have the cd rom disc stratego and I am trying to install it on windows 7 and it will install but it will not let me play it.. is there somewhere where I can buy the cdrom for windows 7 or somehow that I...
This game won't work on Windows 7 in any of the compatability modes. The only way to get this game to work is to run it in windows xp. The good news is that you can get free software from Oracle called virtualbox. Using virtualbox if you have a xp installation disk, you can create a virtual windows xp that runs within your windows 7. Stratego plays fine from within a virtual windows xp, provided that you play from the cd-disk not the virtual hard drive. Install the game normally in the virtual windows xp environment. After installation, to play the game, you must be in virtual windows xp, then double click the CD/DVD drive icon that looks like a bomb. If you try playing from any of the shortcut Stratego (also looks like bombs) launchers or the stratego.exe file installed on your virtual hard drive, the game will not work.Just go to My Computer in the virtual windows xp, and double click the cd/dvd bomb icon, and the game starts up fine.
How do i connect my 360 to the computer
I had this same problem and found this great video on youtube.
go here:
http://www.youtube.com/watch?v=BaKgCYkSCjc
over 175,000 views
if you click the drop down on the info you'll see the step by step instructions.
STEP 1
If you were previously using your Xbox 360 with a Windows XP Media Center Based PC, you will need to remove existing connection. Otherwise skip to step 2.
At the Windows XP Media Center PC
Click Start, point to All Programs, point to Accessories, point to Media Center, and then click Media Center Extender Manager.
Select your Xbox 360 and click Properties.
Click Remove.
Click Yes to confirm removal.
At the Xbox 360
On the Xbox 360, go to My Xbox and then System Settings, then select Computers.
Select Windows Media Center, and then press the A button.
Select Disconnect.
Press the B button until you return back to the System Settings.
STEP 2 Gather Setup Key from Xbox 360
Press the Media Center Start button on the remote or go to My Xbox, then select Windows Media Center.
Advance through the on-screen instructions to obtain the 8 digit Media Center Setup Key. Write this key down.
STEP 3 Add Extender
At the Windows Vista-based Media Center PC, launch Windows Media Center. Select Start, Windows Media Center.
Select Tasks, Add Extender.
When prompted, provide the 8 digit setup key you received at the Xbox 360.
Complete the Extender setup.
STEP 4 Print the Media Center Quick Reference Guide
2helpful
2answers
Windows XP Media Center edition... get a ''Cannot Find Windows Messenger'' error when starting up media center... wouldn't bother me - but my son just got an XBox 360, and it cannot connect to the PC due...
This should a simple fix to enable Messenger if you have your XP disk handy.
Go to "Add/Remove programs"
You will see an add/remove windows components, or something similar.
If the Windows Messenger box is already ticked, untick it and OK it then exit out and go back to this.
Now Tick the box. It may ask you to insert your CD.
Once done, OK it again and restart your PC.
DONE.
If this still causes issues, try downloading Windows Live Messenger (about 175MB) and run it directly from the website. Saving to yourPC has issues and often does not work.
I'm not really clued up with Xbox and other game boxes, so all I have done here is to activate Messenger in one format or another on you PC.
Regards
Xp media center says no ntsc tuner installed
Okay, Media center does not work with some Wintv HVR's yet it will work with the software it came with and sometimes media center will use the wintv software to make it work but its sketchy. If you want a more media center compatiable card look at www.microsoft.com website they have a list of media center compatable Tv tuner cards, Trust me I am having the same problem with my tuner card now and its not wintv its a RCA and its under windows 7 this is just the thing here not all card work with media center.
Thanks for using fixya.com please do click the accept button.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Media Center for Window XP, TV don't work.
Try reinstall windows. If this doesn't work you might have a conflict with your tv-tuner
Black screen after fresh install xpmc 2005
Are you able to go windows safe mode if yes ... Start > Run > Msconfig > Ok
in the general tab you have option to seleect Normal Start up > Click on apply and ok and restart yiur computer that should work
Xbox 360-computer?
To connect the Xbox 360 console to this computer, you must be running Windows XP Service Pack 2, Update Rollup 2 for Windows XP Media Center Edition 2005, or Windows Vista.
To obtain your setup package or instructions for connecting your Xbox 360, select the version of Windows installed on this computer from the following list.
To determine the version of Windows XP Media Center Edition that you are running, follow these steps:
  1. Start Media Center.
  2. On the Settings menu, click General.
  3. Scroll down, and then click About Media Center.
  4. Click Software Version
    The version number of Media Center you are running is displayed.
To determine the version of Windows XP that you are running, follow these steps:
  1. On the Start menu, right-click My Computer, and then click Properties.
  2. On the General tab, under System, look for the version of Windows that you are running.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
