If you want to watch videos on your unit it is necessary to bypass the parking brake wire from the Kenwood unit. The parking brake wire is light green and the best possible way to bypass the unit is by installing a toggle switch. The toggle switch should be a two wire device. Connect one wire to ground and the other wire to the parking brake wire from the unit. This will allow you to switch the supply on the wire to ground when needed.
Also, in some older Kenwood units you could just as easily connect the parking brake wire to ground and be done with it but, it does not always work.
The 404 requires multiple signals from two separate wires to turn off the video block. Simply grounding one wire will not work. There are bypass modules that will send these signals to the head unit available on ebay. Just search alpine 404 bypass. Your other option is to use two toggle switches to simulate the parking brake and foot brake signals necessary to disable the video block.
To bypass the parking brake you should connect the parking brake wire from the unit to ground. It is better to do it via a switch because is illegal to watch video while you're driving. :)
