From what I can tell, you can just press the little wireless "button" located on the touchpad between the screen and the keyboard.
From what I've read this is a semi-rare problem on this laptop. I'll refer you here:http://h20239.www2.hp.com/techcenter/Wir... I hope it helps. Once you've tried that guide let me know how it goes.
Maybe you don't have your wireless turned on. Look on
both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle
the wireless on or off. Normally you would Press and Hold the FN function
key located at the lower left of the keyboard, then hit the correct F1 thru F12
key that toggles the wireless. The correct F1 thru F12 key to hit will
have the wireless signal icon )))) on it. Or it might have the icon of a tower
with the wireless signal icon )))). Normally the screen will display
Wireless On or Wireless Off when you toggle the wireless.
Some laptops might have a wireless button instead of a wireless switch located above the keyboard or on the front or sides.
It will not turn on when I touck it. And I cannot turn the wirelessonin the Windows Mobility center. What should I do?
Thank you
