Acer Aspire 3000 Notebook Logo
Anonymous Posted on Feb 15, 2010
I AM HAVING TROUBLE GETTING THE LAUNCH KEYS TO WORK AS WELL AS THE 4-WAY SCROLL BUTTON BELOW THE MOUSE PAD. I WAS WONDERING IF THERE WAS A DOWNLOAD OR A DRIVER AVAILABLE TO FIX THAT CERTAIN PROBLEM?
electronic & computer repair& servicre
Level 3:
  • Acer Master 12,061 Answers
  • Posted on Feb 15, 2010
Acer Master
Level 3:
Answers
12061
Questions
0
Helped
4008232
Points
36390
Yes you are right. You need launch manager, look for launchm for XP & launchmanger v2.0.02.1 Vista
http://support.acer-euro.com/drivers/notebook/as_3000.html
Testimonial: "Thanks, that did the trick. I have one more question... is there also a driver for the 4-way scroll button below the mouse pad?"
  • electronic & computer repair&  servicre
    Yes there is it is called a "Touch Pad" same place to get that too... Just download and install set it up as to how you want.
Laptop screen frozen;arrow wont move;cant type in user name.ACER Aspire
The appeal to any laptop is the ease of portability of the machine, and an Acer laptop is no different. With an integrated mouse pad, these computers can be quite the boon to those looking to have their technology on the go, but a number of issues can afflict Acer laptops, including unresponsive mouse pads. Fortunately, a few clicks of the keyboard and some driver downloads can alleviate most Acer mouse pad problems.
Take a close look at the Acer laptop mouse buttons. Make sure the exterior of the buttons are clean and that there is no grime around the edges and crevasses of the Acer buttons. Dirt on top of the mouse pad can result in slower performance or an unresponsive experience, while grime around the sides of the mouse buttons can cause problems with the pressing and depressing of the mouse. Is there any way your mouse pad has been turned off? Check into this possibility. On an Acer laptop, hitting the "Function" (Fn) key and "F7" on the key board will result in the mouse pad being switched off. Hence, you may have hit this function and your mouse pad may not actually be broken or require any repair. Hitting the "Fn" button and the "F8" key on the Acer keyboard will result in the mouse pad being turned back on again. Click on the "Printers and Other Hardware" option on your PC. This is an alternative method to the above. At this point, examine the menu that comes up and click on the button at the top that reads "Device Settings." You should then see an option to click on your Acer mousepad. Highlight this option and click "OK." Launch your Web browser and go to the official Acer website. http://www.acerpanam.com/ The above steps may not have worked, so downloading new drivers for your mouse may be necessary. Select your country of origin, then click on "Support." You will be asked to click on your country again. After you do so, click on the link that says "Drivers and Downloads" on the left sidebar. Select your product line ("Notebooks") as well as your specific Acer computer model, and then hit "Search." Click on the link that says "Touchpad drivers." Your Acer computer may only require new drivers for your mousepad. Download the .exe file and run it to install the contents to your Acer computer. Restart your Acer computer after fully completing the download and installation process. Once the restart process has completed, the driver installation will be complete and your mouse should work again.
b>
Scroll not working on aspire 5720z
Instructions
Launch your Web browser and go to the official Acer website. The above steps may not have worked, so downloading new drivers for your mouse may be necessary.
5
6
7
How to unlock a mouse on a laptop
On the top of your keyboard there should be F keys like F1,F2 etc.
Every F key has a little picture.When you see a touchpad picture press Fn+F5. According to my Laptop. For example if your touchpad picture is at F6 then you would press Fn+F6.The Fn key should be located near the ctrl keys. If this does not work then try the following steps:-
1 Click the Windows "Start" button in the bottom-left corner of your desktop. Scroll up and click "Control Panel."
2 Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner. Click the "Enter" button and then click the "Mouse" link.
3 Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have. If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button. If you are under the touch pad tab, click the enable button.
4 Click the "Apply" button and then click the "OK" button.
2answers
Cant get the font to change on a web page that I somehow made smaller
Hello
OK, all you need to do is to hold down the "Ctrl" button on your keyboard. While you hold down the key, you need to scroll with your mouse button, If you have an external mouse plugged in, you just need to scroll with the middle mouse button. If you use the mouse pad on the laptop, the left side on the pad is usually the scroll function.
So...Just to be clear. Open your web browser. Hold down the "Ctrl" key on scroll up or down with your scroll function.
Hope this can be of help. Also, please do not hesitate to let me know if you need any further assistance.
Kind regards
Andrea
Touch pad quit working recently.
Please visit Asus website and download the touch pad driver and manual for your computer mode.
http://www.asus.com/entryflash.htm
32helpful
6answers
Lenovo G550 touchpad scroll bar does not work with windows 7.
Have you tried installing the drivers for the touchpad?
The link below will take you to the driver download page for your laptop, scroll down to the section for touchpad and install either the windows 7 32-bit or 64-bit drivers.
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_list.aspx?CategoryID=600154
My acer aspire 5100 mouse buttons
You have to go through the Control Panel, double click the mouse icon and find the settings for what is actually called a Glide Pad and change any values from there.
98helpful
9answers
Scrolling button on touchpad not working?
SCROLL PAD SOLUTION THAT WORKED FOR ME!!!
Well what I did was I went to CONTROL PANEL, went to the HARDWARE AND DEVICES, went to the DEVICE MANAGER which has a list of Devices. I found the MOUSE DEVICE on the list, right clicked it went to PROPERTIES go to the DRIVER TAB, and then click on ROLL BACK DRIVER. Restart your computer. and then repeat everything again. CONTROL PANEL>DEVICES>MOUSE>PROPERTIES>DRIVER TAB when u get back to the driver tab of your mouse device. click on UPDATE DRIVER. It will then find the driver automatically reinstall it for you and then restart your computer. HOPE this fixes your scroll pad. It did for me.
4helpful
2answers
Turn off scroll button
hold down the fn key and press the scroll button.
7helpful
3answers
Erratic mouse behavior or my mouse has a mind of it's own
GO TO REGISTRY EDIT, FIND HKEY_CONTROLPANEL\MOUSE.
DELETE THE KEYS THEN RESTART WINDOWS.
WINDOWS WILL REBUILD THE KEYS.
IT MAY BE THAT YOUR REG KEY IS CORRUPTED.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
