Question about Lenovo G550-29583AU Notebook
Lenovo G550 touchpad scroll bar does not work with windows 7.
Posted by gmtrshd on
Anonymous
    New Friend:
Have you tried installing the drivers for the touchpad?
The link below will take you to the driver download page for your laptop, scroll down to the section for touchpad and install either the windows 7 32-bit or 64-bit drivers.
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_list.aspx?CategoryID=600154
Posted on Dec 30, 2009
Anonymous
    New Friend:
I had this same problem. This is how I solved it:
1. Install the touch-pad driver from Lenovo's website, but remember which folder it installed into
2. Go into the device manager, it's located in the control panel, and click on mice and other pointing devices, then on the mouse device
3. In the mouse device window, go to drivers, then update driver, then say locate manually, then find the folder you installed the drivers to
4. Restart and try the scroll wheel
Posted on Oct 27, 2010
doxhector
    New Friend:
Anonymous
How to enable scrolling feature of touchpad in XP on G550 Lenevo Laptop.
1.Open Control Panel
2.Double click on Mouse icon.
3.Under Mouse Properties Screen, click on Gestures Tab.
4.Select Auto Scroll option from the Right Corner Assign:Combo box.
5.Click on Use Scroll Function check mark.
6. Then Click on Apply and then OK button.
By the above steps I had enabled scrolling feature of my G550 Laptop that's why I have shared these steps with you, I hope this would help you out.
Regards
Vineet Kaushal
Posted on Aug 15, 2010
hishamchicko
    New Friend:
    Problem Solver:
  • 5 Answers
Go to belove support page and install the vista driver.This is how i solved
Posted on Aug 07, 2011
Anonymous
My lenove g550 with windows7 basic not working the scroll in mouse touch pad? please let me know how to activate that?
Posted on Feb 25, 2010
3 Related Answers
Anonymous
  • 274 Answers
SOURCE: how to install xp in lenovo g550, its cant able
fist go bios & give boot from cd RAM save it exit from there insert XP CD it will ask you press any key ,just pess it then it will start coping fails & drivers after that XP will install ok
Posted on Mar 08, 2010
Ezrahite
Rofel Lantican
  • 2632 Answers
SOURCE: I need to disable my
To be able to Disable the touchpad you need to press FN + F6 to disable it you can enable it by pressing the same keys. Some Helpful Keys that you need to know about Lenovo.
FN + F5 - Enable/Disable Wireless
FN + Esc - Enable/ Disable Webcam
Don't Forget to say Thanks. Thanks for using Fixya.
Posted on Feb 05, 2011
Testimonial: "Thanks for the fix, working fine! thanks again."
Lenovo G550 touchpad scroll bar does not work with windows 7 how can I fix it?
Right! I downloaded the Alps Pointing device (for Vista) from Lenovo site, and updated the PS/2 mouse driver with it and it's working! Thank you jon-snell and fixya community!
Dec 31, 2016 | Lenovo Computers & Internet
How to use the touchpad of lenovo g500 to function for scrolll bar
Hey,
Did you manage to solve the problem? I've got my g500 too, and cannot scroll with the touchpad...
Can you help me?
Oct 08, 2013 | Lenovo G550-29583AU Notebook
I NEED TO REINSTALL THE DRIVERS FOR THE TOUCHPAD AND POINTERS ON MY LENOVO G550
Goto start system, control panel device manager scroll down to human input devices right click and reinstall drivers.
Aug 18, 2012 | Lenovo G530, G550, G560...
Vertical scroll wont work on lenovo g550
Sounds like a driver problem go here: http://consumersupport.lenovo.com/ot/en/driversdownloads/drivers_list.aspx?categoryid=600154
and scroll down to touch pad, and download and install the driver that corresponds to your operating system (windows 7, windows xp etc.)
May 06, 2011 | Lenovo G550-29583AU Notebook
How to change touchpad settings for lenovo g550, I hate this touchpad, please help
You really can't do much with settings for a touchpad. I would recommend disabling it and using a wireless mouse. var fctb_tool=null; function FCTB_Init_c6f64f985d3644929e3995eea1c55206(t) { fctb_tool=t; start(fctb_tool); } var fctb_tool=null; function FCTB_Init_d35d1f3861484992b99b0e9345d90151(t) { fctb_tool=t; start(fctb_tool); }
Feb 03, 2011 | Lenovo G550-29583AU Notebook
When typing, my cursor will randomly jump to some other part of page thus screwing up what I have already typed. I am not accidently hitting touch pad. Lenovo G550 thinkbook Windows 7 proffesional...
Hi rbdav1,
Based on your situation. I suggest trying the following steps:
1. Download touchpad driver from here:
http://consumersupport.lenovo.com/us/en/DriversDownloads/drivers_list.aspx?CategoryID=600154
2. go to Touchpad section and make sure you select the Windows XP, Vista or Windows 7 version of the drivers that matches your Windows operating system.
3. After downloading the touchpad driver driver install it and then restart your computer.
4. Log back in to your computer then go to control panel --> open mouse properties then look for Alps pointing device tab.
5. Under Alps tab uncheck tap off when typing.
Hope it helps.
Thanks for using FixYa
Best regards,
Reyjoshua07
Dec 13, 2010 | Lenovo G550-29583AU Notebook
My lenovo laptop's touchpad scrolling is not working after I installed Windows 7
In lenovo website you need to download the touchpad driver for windows 7.. its easey.. remeber download for the correctly version w 7.. example ultimate or professional or starter.. ok.. pls click my solution was usedfull.. good luck
Dec 27, 2009 | HP Pavilion dv4000 Notebook
SCROLL NOT WORKING ON LENOVO G450 LAPTOP
go to consumer support.lenovo.com. select the model G550 for the option 2 which asks for you to select your product, download the driver for ALPS touchpad and reinstall it to your computer. the scroll function should work after updating the drivers. If it still wont work, go to the control panel and configure it from the mouse properties. you would be given additional options once youve installed the driver
Dec 23, 2009 | Lenovo 3000 Y410 Notebook
Lenovo G550-29583AU Notebook Logo
13,041 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
