This model printer has only an USB connection. It is possible to print wireless by connecting the printer to your computer and sharing your printer on your network that is connected to a wireless router. OR connecting your printer to a wireless router that has an USB port for connecting a printer.
Are you often to used refilled cartridge? That's possible your waste tank has been fulled. Hold down the 'Stop' AND the 'B&W' button while powering up. This seems to clear the error message and restore the printer. Worked for me--dunno how long it will last tho!
fault is caused by counter, which counts printed pages for reason of possible overflow of waste ink pads. To reset counter a free tool is available under::
http://www.ssclg.com/epsone.shtml
this tool has also other advantages of e.g. overdubbing cartridge codes ....
a german instruction for resetting the counter is available here: http://www.druckerchannel.de/artikel.php?ID=1116&seite=13&t=schritt_7_zaehler_zuruecksetzen
make sure to have removed and replaced waste ink pads: http://www.octoink.co.uk/pages/Epson-RX620.html
start program, choose printerport which is used for Epson rx620, choose Epson model rx620 close active window of program ssc -> program will be available by icon in right lower corner. switch on printer right mouse click on program icon in right lower corner will open options: http://www.druckerchannel.de/artikel.php?ID=1116&seite=13&t=schritt_7_zaehler_zuruecksetzen# choose according to picture
This message is advising you that there are certain parts/components in your printer that either require servicing or replacement. You need to consult the manual that came with your printer and follow the directions in the section on maintenance. They may want you to install a service kit or clean/replace parts. If you no longer have this manual, go to the support section of the manufacturer's website and see if you can download a manual for your printer. You will have to enter the model number of your printer.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please return to the FixYa website and rate my response to your question.
Best regards,
Yavacotech
All you need to do is perform a reset, by pressing and holding the "Stop", "B&W", and "Power" buttons all at the same time and holding them down for at least 10-15secs. It may take a few goes as there's a bit of a nack in getting the buttons pushed at the same time.
I had this problem also. What i did was hold down the 'stop' and the 'B&W' buttons while powering up. this erased the error message and now I am up and running fine again.
Thank you I use my printer for home stuff and just
soaked up all extra ink from pad into paper towel and
did the reset is no problem, just hold down the B&W and the Stop button while powering up the printer. Fixed it well. I was quoted $100 to do what took 10 minutes.
Thanks for tip!
