Question about Epson RX620 All-In-One InkJet Photo Printer
Make Epson Photo RX620 print wirelessly
Isit possible to make the Epson Photo RX620 print wirelessly?
Posted by Debbie Cates on
Chris Hingee
  • Epson Master
  • 32,281 Answers
This model printer has only an USB connection.
It is possible to print wireless by connecting the printer to your computer and sharing your printer on your network that is connected to a wireless router.
OR connecting your printer to a wireless router that has an USB port for connecting a printer.
Posted on Aug 05, 2012
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: service requires. End of parts service life message
there is a program out there that you can download http://www.ssclg.com/epsone.shtml not 100% if it works on your model but worth a try
Posted on Aug 25, 2007
Anonymous
  • 14 Answers
SOURCE: Epson stylus photo 810 won't print
Is it just not printing on the paper and feeding it thru, or will it just not do anything? I need more info?
Posted on Dec 05, 2007
Anonymous
SOURCE: Epson Photo RX620: Printing Pink Lines
None of these answers are accurate.  I know precisely what your problem is, and you aren't going to like what I have to say.  What you are experiencing will happen eventually to every Epson printer and there is nothing you can do about it other than to buy a new printer.  I have an Epson Stylus Photo 895 ( a 500 dollar printer in its day), which has the same issue.  I am just waiting for my ink cartridges to run out in order to buy a new one.
Endless research on google has turned up that there is no solution to this problem.  The issue you are having is with the Epson print head, which uses piezo technology.  What that means is that unlike HP or Canon printers which are thermal, piezo uses a small piezoelectrical cell to force ink out of the chamber.  It has advantages over thermal in that thermal requires a precise temperature to get ink on the page (what actually happens is that ink is heated, it forms a bubble, and the bubble bursts onto the page, hence the name BubbleJet).  Therefore, the ink has to have fairly precise thermal ink properties making it more expensive to manufacture.  Also, the ink on a BubbleJet (or HP) is wetter when it hits the page, and since the ink is heat resistant or order to properly form the bubble, the printer needs to incorporate a fast drying technology which consumes more energy.  The massive advantage of thermal is that the print head is on the cartridge, not on the printer itself; change your cartridges, get a brand new print head.  It makes cartridges more expensive, but reduces problems such as what you are experiencing.
Piezo on the other hand, always shoot ink through the same print head.  Once the head become damaged over time, the piezoelectric cell is no longer accurately pushing out the ink, and there is nothing you can do about it.  If you are lucky, it is only dried ink in the print head, but I can almost guarantee you that it is not.  Dried ink can be cleaned by repeated head cleanings, even manual ones involving rubbing alcohol.  However, I know that those pink lines are caused by the deterioration of the cell, and cannot be fixed.  If if were only dried ink, you wouldn't be limited to just pink lines on the page, you would see other colours.  If the cell is not doing its job, the lines are always pink (often called magenta when you google this problem).  The solution is to acquire a new print head.  Unfortunately, the cost of replacing an Epson print head is IDENTICAL to the cost of a new Epson printer.
So basically you have no choice, you need to buy a new printer.  Were I you, I would purchase a new thermal inkjet printer so that you get a new print head with every cartridge.  Look around before you buy to find out exactly how much the cartridges will cost, and then you will know which brand to buy.  Although piezo *can* make for a cheaper printer at the outset, Epson simply charged what HP and Canon do for their replacement cartridges because that is what people are used to paying, but you really do get more in a thermal inkjet catridge.
Sorry for the bad news,
DD.
Posted on Oct 25, 2007
Anonymous
  • 5 Answers
SOURCE: Is there anyway I can scan with no ink Epson photo RX620
I'm not certain that I can help, but I am familiar with the Epson does things with their printers and all-in-ones. The thing is, printers are pretty cheap to buy. Where these companies make lotsa bucks is in the aftermarket products, which in this case is printer ink. Therefore, these printers are designed to now allow you to do much of anything with all the ink cartridges installed. I can certainly understand your frustration, and if I am wrong about this, I would like someone who considers themselves an "expert" to tell me so. Good luck, and my advice would be, next time don't buy an Epson. They are the worst company for high-priced ink, and if you use anything except Epson brand ink, you void the warranty. Sucks!
Posted on Mar 17, 2009
loumsc
Louis Davidson
  • 114 Answers
SOURCE: An Epson RX620 Printer cant print from windows 7
I use the Windows XP SP2 drivers with Win 7. Before installing them, right click on the driver file, select properties, select compatibility and the select Win XP SP2.
Lou
Posted on Sep 13, 2009
Testimonial: "Thanks very much! Im downloading now!"
My epson stylus photo rx620 has a scanner erro and is not printing
Generally, the 1st best troubleshooting step is to uninstall the printer drivers, unplug the usb cable then download and install the latest driver from the manufacturer's web site, then re-connect the printer when prompted to in the installation of the new driver.
Sep 26, 2011 | Epson Stylus Photo RX620 All-In-One InkJet...
I would like to buy a users manual for Epson/Stylus Photo RX620 Judy Hunt
hi
just go t Epson site you will get free user manual for your printer or go to following link you will get your manual
http://www.devicemanuals.com/guide/Printers/Epson/Epson-Stylus-Photo-RX620-User-Guide-TXpNd05qST.html
Oct 12, 2010 | Epson Stylus Photo RX620 All-In-One InkJet...
It won't print after installation of new ink jet
Here's a link to the Epson printer troubleshooting guide...if this helps; please indicate so.
http://er.epson.com:8001/start
Nov 10, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Lou
Sep 13, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
RX620 do not print black text
When the printer screen appears, click on Advanced. That should bring up another screen where you can choose to print in "grayscale." This will not give you a deep black print, but it will eliminate any color printing. Hope this helps.
Mar 15, 2009 | Epson Stylus Photo RX620 All-In-One InkJet...
Epsom RX620 Poor quality photo prints
I have got round this problem by routing my pictures via Picasa 2. Printing direct is still a problem, but I think I can live with that for now.
Richard
Nov 18, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson Stylus Photo RX620 Printer
Hi
If its E-90 error then there is a hardware problem with the printer already.
Hope this helps
Oct 13, 2008 | Epson Stylus Photo RX620 All-In-One InkJet...
RX620 inconsistently only prints part of the page
The epson printer RX 620 only prints partially for my photo while I want the whole picture. How do I get it to print the whole thing instead of it printing it partially?
Apr 13, 2008 | Epson RX620 All-In-One InkJet Photo...
Epson RX620 All-In-One InkJet Photo Printer Logo
582 people viewed this question
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
