This printer is 3 years old and is not over used.It has developed poor quality text which hasn't improved by going through all maintenance procedures.I am so frustrated that I'm thinking of replacing it with a new one but not Dell. I was never impressed with it in the first place.What do you think?
I have to ask this question of you, just to make sure this is not an issue.Are you using a factory new ink cartridge? Please consider the following: If you are using a refilled or third party cartridge that may well be your problem.Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges. They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead. If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges Don
Digital answer phones record the message on a memory chipset in the same way old tape machines did using a magnetic support. Quality can only be improved by the technology itself, problem is with your specific machine. If you have a broadband filter try replacing it. Test the machine on a different phone socket and see if it makes any difference. Check on your answering machine settings, you should find an option to control volume.
Whats the question?? if poor quality printing, it could be dirty ink cartridges, dirt on the print head, poor quality paper ??? try looking at the printer settings, sometimes they may be set to economy rather than top quality printing.
The lines are more than likely caused by either the Drum, Developer or Fuser unit. I have found in many cases that if non genuine toner is being used this will give you poor quality images. You can try using genuine toner which may resolve your issue but you may have to run a few hundred prints to clear out the old toner before the image improves.
This sounds like the doctor blade within the black developer unit inside the image unit has become contaminated. This means that not enough black toner will be attracted to the developer roller. This usually manifests itself as feint thin lines of print running vertically through the text being printed. This can be repaired and is a known issue with this image unit.
If the printer is in warranty tell them you want it replaced, if not then take the image unit back to the supplier you bought it from and demand a replacement.
there are 3 reason if the copy gray & less sharp:
1) the toner you are using is not compatible very well with the cartridge unit if you changed other compatible toner.
2) the cartridge going near the life-cycle, (also cause print blurred)
3) the photo drum going near the life-cycle
you may try to change the quality toner (original factory). or
change the cartridge if it is out of the life-cycle
