So you are using this cable to connect to the TV? On this cable is there only a red, yellow & white connector? This is known as an S-Video or AV cable.
Can you make sure you are connecting it in the right part of your TV. Once connecting it you will need to select the AV input on your TV or you may need to tune the TV into that input (depending on your TV age/model)
The best connection for the PS3 would be the HDMI cable which is one lead with one connector at either end (though this is for HD TVs only)
if you have not changed your pin from the one supplied when new ring the supplying dealer, they will have it on record.If you have changed it and cant now remember contact your local B&O dealer who will request a mastercode for the set but this will require proof of purchase.
yes it could be a fuse but moust of the time
the fuse is blowing because power suger/or bad flyback/hozoutput/or power supply whent bad. unplug the tv .take off the back and look for the fuse you see the power cord it by the powercord if the fuse is black it a hard blow.
if you can see thur it .it a sofe blow you can try to chang it.6.1amp fuse125v or it could be 250v fuse6.1amp and if the fuse blow agon you have a short powersupply
You can try turning on the video game and changing that tv stations as low as they'll go. sometimes the station will go from 3, 2, aux, side video, av1, av2, etc.. Hopoe the info helps GOD Bless You
