Cars & Trucks Logo
Posted on Feb 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Front wipers will not work in interval mode, the slowest, and will not go all the way down when I turn them off. They work on the middle setting and the fastest but don't otherwise. Can't be a motor issue if they still run. Is this a switch issue?
Ramy de Jesus
Level 3:
  • Master 377 Answers
  • Posted on Feb 08, 2010
Ramy de Jesus
Master
Level 3:
Answers
377
Questions
0
Helped
110244
Points
1323
  • In my openion it is a motor issue try to check the motor and also to be sure go to a good electrician.
I’m happy to assist further over the phone at https://www.6ya.com/expert/ramy_d9e7ebea3891f482
1helpful
2009 Pontiac G6 Pulse setting on wipers. When on pulse the wiper goes halfway. After the next interval they go the remainder then return properly.
You didn't take into account the wiper switch is a input to the BCM - body control module ,or do you know that ? The BCM controls wiper one an wiper two relay's to turn on the wipers .
Wondering if it is the PCB or perhaps a physical problem? Guessing never finds the problem . Reading how they work in factory service repair info should be the first step for someone that doesn't know .
Intermittent Operation
Windshield wiper DELAY operation is a low speed wiper motor function with a variable delay interval between the wiper motor cycles. The DELAY interval is determined by a series of 5 resistors within the wiper/washer switch. During DELAY wiper operation, the signal circuit voltage is further reduced through the DELAY resistors. The body control module (BCM) monitors the voltage on the signal circuit to determine the delay interval between the low speed wiper motor cycles.
If the wiper switch is moved from a longer delay interval to a shorter delay interval, the BCM will command an immediate wipe cycle and reset the delay timer to the shorter delay interval.
Additionally, intermittent wiper operation is vehicle speed sensitive. As vehicle speed is increased or decreased, the wiper interval will also increase or decrease.
Low Speed Operation
When the wiper switch is in the Low position, voltage is supplied through an internal resistor to the signal circuit. The body control module (BCM) monitors the windshield wiper switch signal 1 circuit and energizes the wiper 1 relay which will operate the windshield wiper motor. The wiper motor will operate at low speed, since the wiper 2 relay is de-energized. Low speed can also be commanded with a scan tool by commanding Wiper Relay Cmd. ON and OFF.
High Speed Operation
In the High position, the windshield wiper/washer switch supplies voltage to both the wiper 1 and wiper 2 relay coils. This energizes both relays and allows battery voltage from the wiper 1 relay switched output to the switched input of the wiper 2 relay through its contacts and out the switched output of the wiper 2 relay to the high speed circuit of the windshield wiper motor. The windshield wiper motor will operate at high speed. During HIGH speed wiper motor operation, the wiper switch signal circuit is at the LOW speed signal voltage, and the body control module (BCM) supplies redundant voltage to the wiper relay via the wiper diode.
Wiper/Washer System Components
The Wiper/Washer System consists of the following components:
• Windshield wiper/washer switch
• Body control module (BCM)
• Wiper 1 relay
• Wiper 2 relay
• Wiper diode
• Windshield wiper motor
• Windshield washer pump
• Windshield washer nozzles
• Windshield washer solvent container
• Windshield wiper arm and blade assemblies
• Windshield wiper transmission
• WIPER/SW 10A fuse
• WIPER 25A fuse
Refer to Master Electrical Component List.
DTC B3715 02: Front Wiper Relay Drive Circuit Short to Ground
DTC B3715 05: Front Wiper Relay Drive Circuit Short to Battery or Open
Your best bet , take it to a qualified repair shop.
Where is the relay and fuse for rear wiper located ?
The rear wiper / washers are controlled by the GEM - generic electronic module .
NOTE: The generic electronic module (GEM) will not activate the rear wiper system if either the liftgate or the liftgate glass is ajar. If either the liftgate or the liftgate glass becomes ajar while the rear wiper is in operation, the GEM will park the rear wiper motor.
There are two distinct modes of wiper operation:
  • Off Mode: In this mode, there is no rear wiper activity, and the wiper motor will be in the PARK position.
  • Interval Mode: This mode is selected when the rear wiper switch is in either the Interval 1 or 2 position. When this mode is selected, the rear wiper motor is driven up onto the glass by activating the rear wiper UP relay. When the wiper motor HIGH/LOW/PARK position input reaches the high position, the UP relay is deactivated and the DOWN relay is activated to reverse the wiper motor direction. When the wiper motor reaches the LOW position, as determined by the HIGH/LOW/PARK position input, the GEM deactivates the DOWN relay and will begin a new wiper cycle 1 to 10 seconds later, depending on the interval position selected.
Inspection and Verification
  1. The wiper/washer system is a generic electronic module (GEM) controlled system; refer to Section 419-10 .
  1. Verify the customer concern by operating the wiper/washer system.
  1. Visually inspect for obvious signs of mechanical and electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Hoses to windshield washer pump
  • Wiper linkage
  • Fuses 6 (5A), 8 (5A), 15 (5A), and 20 (5A)
  • Wiring harness
  • Loose or corroded connector(s)
  • Relays
  • Motors
  • Multifunction switch
  • Washer fluid level switch
  1. If the concern remains after the inspection, connect New Generation STAR (NGS) Tester to the data link connector (DLC) located beneath the instrument panel and select the vehicle to be tested from the NGS menu. If NGS Tester does not communicate with the vehicle:
    • Check that the program card is properly installed.
    • Check the connections to the vehicle.
    • Check the ignition switch position.
  1. If NGS Tester still does not communicate with the vehicle, refer to the New Generation STAR Tester manual.
  1. Perform the DATA LINK DIAGNOSTIC TEST. If NGS Tester responds with:
    • CKT914, CKT915 or CKT70 = ALL ECUS NO RESP/NOT EQUIP, refer to Section 418-00 .
    • NO RESPONSE/NOT EQUIPPED for generic electronic module (GEM), go to Pinpoint Test M.
    • SYSTEM PASSED, retrieve and record the continuous diagnostic trouble codes (DTCs), erase the continuous DTCs and perform self-test diagnostics for the GEM.
  1. If the DTCs retrieved are related to the concern, go to GEM Diagnostic Trouble Code (DTC) Index to continue diagnostics.
  1. If no DTCs related to the concern are retrieved, proceed to Symptom Chart to continue diagnostics. Your best bet is take this to a ASE certified repair shop !
Wipers stop in the middle of my wishield,will not park properly
Sorry , no adjustment .
The Wiper / Washer System consists of the following components:
• Windshield wiper / washer switch
• Windshield wiper system module / motor
• Windshield washer fluid pump
• Windshield washer fluid level switch
• WPR 25A fuse
Wiper / Washer System Operation
The windshield wiper motor module is part of the windshield wiper motor cover and controls the wiper motor operation. The windshield wiper motor is a 2 speed motor. Windshield wiper DELAY operation is a low speed wiper motor function with a variable delay interval between the wipe cycles. The DELAY interval is controlled through a series of resistors within the wiper / washer switch.
Park Position Operation
When the windshield wiper / washer switch is turned to the OFF position while the wiper motor is somewhere in mid-cycle, the wiper motor module will continue to operate the wiper motor until the wipers reach the park position. If the ignition is turned off while the wipers are in mid-cycle, the wipers will stop immediately where they are. The wipers will park the next time the ignition is cycled to the ON position.
Do you know how to do diagnostic's ?
Wipers Blades Do Not Park
Step
Action
Yes
No
Schematic Reference: Wiper/Washer Schematics
Connector End View Reference: Wiper/Washer Connector End Views
DEFINITION: This table diagnoses the wipers operate normally but will not return to the park position when the wiper operation is cancelled.
Did you perform the Diagnostic System Check - Vehicle?
YES - Go to Step 2
NO - Go to Diagnostic System Check - Vehicle in Vehicle DTC Information
Turn ON the ignition, with the engine OFF.
Move the wiper switch to the LO position.
Move the wiper switch to the OFF position.
Do the front wipers advance to the park position?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring Systems
NO - Go to Step 3
Turn the ignition switch to the RUN position.
Turn the wiper switch to OFF.
Disconnect the wiper/washer switch connector.
Do the wipers park?
YES - Go to Step 7
NO - Go to Step 4
At the wiper/washer switch connector, measure the voltage of the windshield wiper switch signal 2 circuit.
Does the voltage measure greater than 1.0 volts?
YES - Go to Step 5
NO - Go to Step 8
5
Reconnect the wiper/washer switch connector.
Disconnect the wiper motor connector.
Measure the voltage of the windshield wiper switch signal 2 circuit.
YES - Go to Step 6
NO - Go to Step 8
6
Repair a short to battery positive voltage in the windshield wiper switch signal 2 circuit. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
YES - Did you find and correct the condition?
NO - Go to Step 9
7
Replace the wiper/washer switch. Refer to Turn Signal Multifunction Switch Replacement in Steering Wheel and Column - Tilt.
YES - Did you complete the replacement?
NO - Go to Step 9
8
Replace the wiper motor cover. Refer to Wiper Motor Cover Replacement .
NO - Go to Step 9
9
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Step 2
Wipers would not park, customer forced down wiper arm and broke off arm. Now no electric to wipers.
Before 1995 Ford interval wiper systems mainly consisted of a switch, the motor and the interval governor (also called the wiper control module or 'WCM'). The basic wiper systems just parked the wipers at the end of their travel at the base of the windshield and involved just one park switch.
The more complex systems not only stopped the wipers at the base of the windshield, but would actually recess them below the windshield to park them. This involved using two park switches to turn the wiper motor in a reverse direction. These were installed on the Crown Victoria, Grand Marquis, Town Car, Taurus and Sable.
The wiper switch (named 'Multi-Function Switch' on most models) had a common return or ground circuit and two input or signal circuits to the WCM. Basically, the switch was two modified potentiometers that varied the resistance to ground for the two signal circuits. When the wiper switch was placed in the low or high position, the WCM looked at only one of the circuits- the 'mode input' -and controlled the wiper motor accordingly. If the wiper switch was placed in any of the interval positions, the mode input told the WCM that the switch was in an interval position. The WCM then looked at the second input - the 'delay input' - and used it to determine the amount of delay between wipes.
1) To run the wipers on low or high speed, the WCM provided constant power to the wiper motor on the proper circuit to provide the requested speed. Dual park switch motors
1.1 The first park switch operated basically in the same way as the single switch systems.
1.2 The second park switch worked in the opposite manner- when the wipers were off the park position, the second switch provided a ground for the wiper motor. Power and ground were now provided by the park switches.
1.3 When the wipers needed to park, the polarity of the switches changed, and thus provided reversed voltage to drive the motor in the opposite direction.
2) To run the interval wipers, the WCM applied voltage to the wiper motor only momentarily to get the wipers off the parked position.
3) The electro-mechanical park switch made a circuit between the power feed in and the output to the WCM. Power was provided from the park switch through the WCM and back to the wiper motor.
4) When the wipers reached the park position, the park switch made a circuit between the ground and the output to the WCM, and the motor stopped running. The wiper motor and the wiper switch have remained much the same as the single park switch motors of the past.
The main difference is that the switch has become an input to the GEM instead of the WCM.
1) When the wiper switch is placed in the low or high position, the Run-Park relay is grounded by the GEM to provide constant voltage to the High-Low relay, which then provides voltage to the proper circuit of the wiper motor.
2) High-Low relay is in the low speed position unless grounded by the GEM.
3) The park switch not only feeds the Run-Park relay but is now also an input to the GEM. This tells the GEM when the wipers are in the parked position so it can de-energize the Run-Park relay.
4) When any of the interval positions are selected, the Run-Park relay is momentarily grounded to get the wipers off the parked position
5) The park switch then provides voltage to the other set of contacts in the Run-Park relay.
6) When the GEM de-energizes the Run- Park relay, voltage is still provided from the park switch to the High-Low relay and the wipers complete the stroke.
Click over diagrams for zoom:
Hope this helps.
1helpful
I have replaced the wiper switch on my 1990 F 250 and it still is not working properly. Since the wipers work I am assuming it is not the motor. That seems to indicate it is something called the...
Hi:
If your truck has a wiper switch that you rotate counter clockwise to get the intermittent wipe mode, and turn clockwise to get to the low and high settings, then your truck has a interval wiper relay module. You could have a bad wiper switch assembly too, as the intermittent part of the switch is seperate from the low and high wiper switch. It is a inexpensive part, less than $20 for the switch, and the interval wiper relay part is somewhat expensive, 70-100 bucks or so. My truck didn't have intermittent wipers when I bought it, so I went to a junk yard and removed a switch and a module from a wrecked truck for $40, and it has worked fine ever since. Maybe you can find a good used part to swap into your truck for testing? Once you buy new electrical parts, you cant return them!
Nissan Primera 2000 Windscreen Wiper Interval mode won't work.
are u sure is not a relay thats the problem? ie the relay thinking to one speed?
1helpful
Need to get a programmer dont know where its at
  • Windshield Wipers Continue to Run When Turn Signal and Windshield Wiper Switch Are Turned OFF
  • Damaged turn signal and windshield wiper switch .
  • Damaged windshield wiper motor .
  • Damaged windshield wiper control module.
Pin Number Circuit Circuit Function 1 57 (BK) Wiper Motor Ground (Park) 2 28 (BK/PK) Wiper Module to Wiper Motor (Park Switch) 3 65 (DG) Wiper Motor Power (Park Feed) 4 61 (Y/R) Wiper Motor Common (RUN) 5 56 (DB/O) Wiper Motor LO 6 58 (W) Wiper Motor HI
Windshield Wiper System The windshield wiper system consists of :
  • Windshield wiper motor (17508) (F-type).
  • Washer system.
  • Windshield wiper control module.
  • Turn signal and windshield wiper switch (13K359).
The windshield wiper control module is:
  • Located at the instrument panel fuse panel.
The windshield wiper motor is:
  • Attached to the cowl top extension (021A36) .
  • Connected to windshield wiper mounting arm and pivot shaft (17566) .
The turn signal and windshield wiper switch features a:
  • Rotary wiper switch.
  • Push type washer actuator.
OFF/Low/High Speed
  • Has a two-speed, permanent magnet, three brush electric windshield wiper motor .
  • The windshield wiper motor has a brush rigging that permits selection of low or high speed.
  • When the turn signal and windshield wiper switch is in the LO position, the common brush and the blue/orange wire brush are used, and the windshield wiper motor operates at low speed.
  • When the turn signal and windshield wiper switch is in the HI position, the common brush and the white wire brush are used.
  • In HI position, electric current will bypass a portion of the armature winding causing the windshield wiper motor to operate faster.
  • When the turn signal and windshield wiper switch is moved to the OFF position, the windshield wiper motor will continue at low speed until the park switch outer contacts open.
  • When the park switch contacts open, the windshield wiper motor stops in the park position.
Interval
When the turn signal and windshield wiper switch is in the interval position:
  • The wipers make single wipes separated by pauses.
  • The rotary switch is on the end of turn signal and windshield wiper switch .
  • The length of the pause can be set from approximately 1 to 17 seconds.
  • Length of pause decreases as the rotary switch is rotated away from off.
  • Length of pause increases as the rotary switch is rotated toward off.
While in the interval wiper mode:
  • It is normal to hear a slight click at the beginning of each on/pause cycle. NOTE: When using interval wipers, the first wipe may not occur until after a pause of up to 17 seconds.
3helpful
2answers
The rear wiper on my '99 model exped isnt working ,ford global says its the motor and it will cost me P13k . any one who can help me find a mechanic do some repair on this?
what is P13K?
check the fuse first. dealer can hook up NGS Tester and get fault codes to see what is wrong.
Principles of Operation
To engage the rear window washer, rotate the rear window washer selector downward to the WASH position. The rear window wiper will run as long as the WASH position is selected. When the rear window washer selector returns to the OFF, INT 1 or INT 2 position, the washer will stop immediately, but the rear window wiper will continue for two to three sweeps and then return to its previous mode of operation.
The low washer fluid indicator chime warns that the washer fluid level is low. The low washer fluid indicator chime is a single tone with a duration of one second. The chime will sound when the low washer fluid indicator is initially activated.
The low washer fluid indicator warns that the fluid level in the washer reservoir is low. The low washer fluid indicator will illuminate when the washer fluid level is low and the ignition switch is in the RUN position.
The low washer fluid indicator will deactivate when the washer fluid reservoir is filled and the ignition switch has been cycled from RUN to OFF, then to RUN.
  • Wiper linkage
  • Wiring harness
  • Relays
  • Motors
  • The wipers are inoperative — rear
  • Fuses 6 (5A), 8 (5A), 15 (5A), and 20 (5A).
  • Circuitry.
  • GEM.
  • Multifunction switch (wiper/washer switch).
  • Rear wiper up relay.
  • Rear wiper down relay.
  • Rear wiper motor.
Instructions for turning on back screen wiper on Ford mondeo 1.8
2 ways this could work. 1 is by pushing the wiper switch towards the dash.
2nd is when you pull the lever towards you, it will turn the intermittant wipe on, pull it towards you again to cancel.
TL
Top Toyota Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
ROBERT GARCIA
ROBERT GARCIA
Are you a Toyota Expert? Answer questions, earn points and help others
