Televison & Video Logo
Posted on Feb 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Macrovision I have just bought a Pioneer DV-300 DVD player to play through my 15-year old Sharp 14VT10NZ television. I can only plug it into the AV input. The picture keeps on fading in and out. Is this something to do with Macrovision? If so, how can I disable it?
A
Anonymous
Hello again. I should have been more specific (posted this before I had done all my homework). The TV is actually a TV/VCR combination machine. I believe that the problem may be that the signal from the DVD player passes through the VCR component before reaching the screen, and DVD discs with macrovision coding will cause the fade-out phenomenon. Is there any way around this? Would an RF convertor (DVD signal going into antenna aerial) or a digital video stabiliser be worth trying? I really don't want to ditch the TV/VCR yet as it is a brilliant machine, and I don't want all the extra clutter of separate VCR, cables, remotes etc. Thanks
Anonymous
Level 3:
Genius:
  • Master 1,019 Answers
  • Posted on Feb 22, 2008
Anonymous
Master
Level 3:
Genius:
Answers
1019
Questions
Helped
388760
Points
2735
This sounds like a compatability issue.
If you buy a new DVD, you gotta buy a new T/V to go with it.
Alternatively, you could try a scart box and cable through that.
Or try outputting through the antenna via coax, see if any of these resolve your problems.
Regards Mike @ Compurepair.
1helpful
DVD player automatically stops and turns itself off, how do I prevent this?
Warning: Laser inside! If you want to open it up and troubleshoot, make sure you don't point toward your eyes.
Check the nylon laser carriage to see if it slides laser from center to outside line. If it sticks, it's probably shutting down from not properly reading a disk.
tip
Pioneer region free code DV-340, DV-343, DV-444, DV-545
Introduction
The Px4x DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the DVD player.
Main Features
The DVD Upgrade adds the following features to your DVD player:
 Multiregion capability
 Macrovision disable
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Pioneer DV-340, Pioneer DV-343
 Pioneer DV-444
 Pioneer DV-545
Modification Details
Multiregion selection
Nearly all DVD discs on the market today are encoded with a specific "region" in mind and are made in such a way that a disc designed for "region 1" will not play on a player designed for "region 2". This is so that the Hollywood studios can control the release of titles in different geographical regions all over the world. Our upgrade allows you to select between regions 1 to 6.
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD Upgrade disables Macrovision to solve any problems.
Operating Instructions
You can select the region code by remote. This region will be tried first when playing a disk.
Due to this design, the modification will work on the RCE (Regional Code Enhancement) protected DVD’s. In some cases it will be necessary to insert a conventional (non RCE protected) disc before playing a RCE protected disc. Follow the instructions as detailed bellow:
1. Turn the player on without a disc in it
2. On the remote control, press 'SETUP'
3. Use right arrow to select 'General'
4. Use down arrow to select 'Basic'
5. Press 'ENTER' on the remote control
6. Press 'Display' on the remote control
You should see the region code and OSD version that the player is set to
7. Press 'Condition/Memory'
8. Press '1', '2', '3', '4', '5' or '6' to change the region code of the player
The text will disappear
9. Press ' Display ' on the remote to control the region
10. Press 'SETUP' on the remote to exit. Play the disc
This dident work for me but mayby work for you.
on Mar 06, 2010 • Televison & Video
2helpful
Pioneer DV-410V-K DVD Player Codes region unlock, thanks in advance, I am in Caracas, Venezuela.
I have the Pioonerr DVD -410V-K and would like to unlock it it will not play any UK DVD's. The DVD was made in Thailand and was bought in Vietnam
1helpful
How to use the usb port on Pioneer DV-410V DVD Player
Dear friends in problem solving.
My husband actually solved this problem by writing in the browser: Manual for Pioneer DV-410V DVD player.
That was available online and there it said that not all formats was supported by the USB port, so we tried to load a movie on a pen drive, insert it in the player and it opened and we just clicked play, so it was actually an issue of having an incompatible video file on the pen drive that made it not open in the first place.
Hugs from Solvejg
Plays CDs but not DVDs
try it on diff plug or open it must be sme wire has been broken
Sharp DV-RW2, RW2U w/Pioneer DV 104 inside, need to replace?
it is time to buy a new set my friend.replacement parts for such player is hard to find.good luck.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
