Product: Frigidaire 3.5 Front LoadingWasher
Model # LTF2140ES3
Machine will run through entire cycleand will not spin. It quits at the spin cycle. I checked the Blackboot at the bottom. Removed and cleared out coins. Checked pump- itwas turning freely. Reinstalled boot.
Error message 43 which indicatescontrol board problem. I ordered control board part# 13700500 Installed- same error message. Unit will not spin. Will operatethrough all cycle and stops at spin. Ran diagnostic test. Turnedprogram knob 8 clicks from start to position 8- Delicate. The drainpump and door lock solenoid will activate and the washer will operatein high spin and drain. Error code 43 repeats.
SOURCE: Machine will run through entire cycle and will not
I had a similar problem and found out the "latch" on the washer door broke off. The machine won't run in spin cycle if the door is"open", but it would run through the wash cycle.
