Assuming that you have followed the below correctly DHCP will be enabled.
Step 1: With the unit on, place a paper clip into the hole on the back of the unit labeled Reset.
Step 2: Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3: The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
if not change your computers IP to 192.168.0.2 with 255.255.255.0 mask. Then open the browser of your choice and go to 192.168.0.1 and login to the router and under advanced, reset router to factory defaults.
It might be that your pc has the same ip address as the router, this sometimes happens, best way i found to sort this is to set my pc with its own ip addy, somthing way out the range of the router, say something like 192.168.10.9 that normally sorts it hope that helps
