I had a power outage one day and my 32" Toshiba stopped working, no picture at all and the next day another power outage did the same to my 6420FF plugged in to the same outlet. What gets ruined, is there any hope for saving the 6420FF?
mbj
SOURCE: Sylvania Model 6420FF Television - How Do you Adjust Color?
Hit menu on your remote - click on picture - scroll to color If you need a copy of your owners manual please click here
I’m happy to assist further over the phone at https://www.6ya.com/expert/lou_afa492c634393790
SOURCE: Need remote code for Sylvania 32" LC320SS9 for Dish controller
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Let me know how it goes and please rate this solution
Lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
The power surges have probably blown the fuse in the power supply board. This may not be the only problem.If you are still under warranty, you will need to have it serviced at a service center. If not You will need to find a repair person or center to open the unit and test it for you. This television and all your electronic equipment should be protected with surge protectors. The reason is your power company has problem with power outages and this will damage your equipment. There is no built in self defense for this equipment due to the huge variants involved with power companies. You should call Insignia and ask them where you can find a authorized service center. You can call the Insignia customer support at this telephone number 1-877-467-4289. Tell them the model number of your television and the problem you have had with its failure to turn on.They will be able to help you find a service center to test and repair your television. I hope this information helps you with your problem.
SOURCE: 32" Sylvania TV/DVD won't work with my AT&T UVerse Remote
I bought a 32 inch sylvania LD320SSX TV/DVD and had trouble with a Media-Com remote. Finally got it to work using code 1864
Good Luck
