Most washers have 2 motors (Main washer motor and pump out motor in line with outlet pipe). You need to have washer switched off and works easier when on a small table. You need to open back bottom pannel and side pannels. Both motors have push on electrical connectors and are mounted on removable rubber mountings. Disconnect the pipes (clamps)to the motors electrical connectors and pull from rubber mountings.
Wiper Motor and Linkage
Removal and Installation
1. Open hood and remove wiper arms
2. Remove cowl top plastic cover
3. Remove attaching screws or mounting nuts from pivots
4. Disconnect wiper motor wiring harness connector
5. Remove 3 motor mounting bracket-to-body bolts
6. remove motor bracket, motor and linkage assembly from cowl
7. Remove motor-to-bracket mounting bolts and remove motor
8. Reverse procedure to install
Prior to removing a wheel that is to be reused, clean any corrosion from the blower motor shaft to prevent damage to the wheel mounting shaft.
Blower motor cooling hose
Blower motor mounting plate
To install:
there is only a pump and replacing it is worthless....
