20 Most Recent Hoveround MPV5 Electric Wheelchair - Used Power Chairs Questions & Answers
Hoveround MPV5 had 12v-27 amp batteries in it and I put 12v-35amp in it. Would the 12v-35 amp batteries make the motor get hot? The motor gets hot and the new batteries 12v-35 amp go down real fast.
The larger batteries should have made them run for longer on a single charge. They aren't 35 amp batteries, they are 35 amp *hour*. 12 volts is the thing that matters. Check the batteries are correctly fitted and make sure the motors are clean. The fact they go down faster is puzzling and for that, I would exchange the batteries as they sound faulty.Answer Edited for clarity. However, the motors are now the issue.
5/4/2023 11:57:46 PM • Hoveround MPV5... • Answered on May 04, 2023
My mom has a 10yr old MPV5. It stopped working and showed 7 bars rapidly flashing. The manual shows this to be a joystick issue.
hi,l have you checked the connections from the joystick to the controller situated under the seat ? what is the name of the joystick and there should be a model no etc ? regards Rob www.gewizrepairs.co.uk
1/2/2020 4:35:46 PM • Hoveround MPV5... • Answered on Jan 02, 2020
2answers
Swivel release bar and lock mechanism not working
The swivel lever spring needs to be replaced.
4/6/2017 4:10:38 PM • Hoveround MPV5... • Answered on Apr 06, 2017
My chair has been sitting for three years now won't take a charge and run did the main battery die
Time for a new battery. The worst thing you can do to a battery is let it sit for a long time. Once the battery was activated it is best to keep it charged while not in use. Use a trickle charger while storing your chair.
8/26/2016 3:51:16 PM • Hoveround MPV5... • Answered on Aug 26, 2016
2answers
I need to remove tire?
You will need Socket wrenches, a big ***** Driver and air valve tool if there is a pneumatic tire involved, two 3"-5/16" bolts w/nuts and washers. I like to tip the chair on its side. and loosen the main shaft nut and remove it. Then wiggle the tire back and forth, then lift. If you are lucky it will slide right off. then you can let the air out of your inner tube or go straight to removing the split rim bolts. the ***** driver is used between the rim and tire and pry apart the tire from the rim, work around the the rim until the tire is off on both sides, If this is a foam filled tire then you will need 2 5/16" Bolts w/ nuts and washers replace the tire and line up the hole for the bolts and push the rims together so the long bolts can make it long enough to put the nut on. the nut down a little then put another one on opposite side to pull the wheel in tighten the bolts a little on each side evenly until the original bolts are able to be used to tighten then take out long bolts and install all the rest of the shorter bolts. tighten them up and grease the shaft and put the shaft key in the slot and gently put the wheel on and tighten the shaft nut. Check to see the wheel turns with the shaft. the key can slide out some times Then tip the chair up and see how it drives. Sorry no pictures yet. I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
4/13/2016 11:25:07 PM • Hoveround MPV5... • Answered on Apr 13, 2016
Hover round mpv5 , what size wench to remove tire
To remove Drive wheel 15mm 17mm 19mm are normal sizes, to separate the split rim for tire replacement, 7/16, 3/8. I would use a socket set. I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
4/9/2016 2:54:41 PM • Hoveround MPV5... • Answered on Apr 09, 2016
Cant charge it Lights keep blinking and the only thing that works is the horn.
Before charging, make sure the unit is turned off. Connect the charger to the wall outlet first and then to the chair. Check that the battery cables are attached fully to the control box. Turn on charger. After charging, remove charger and verify the unit is fully in gear. The levers must be fully in the up position. If the lights still flash, some wiring is probably loose, or the drives are not fully engaged.
6/20/2015 8:33:37 AM • Hoveround MPV5... • Answered on Jun 20, 2015
Hoveround won't move.
Double check to be sure drive levers are fully engaged. Go down and up a few times. If problem persists have Hoveround come and check it out. One of the drive motors may have shorted out when you continued driving with gravel in the wheel.
4/3/2015 12:28:12 PM • Hoveround MPV5... • Answered on Apr 03, 2015
How do you change batteries on hoveround mpv5 ?
Disconnect cables going from battery boxes to the control box. There is probably a catch that needs to be squeezed in, then pull and wigglt the connection block until it disengages. Release the straps over the battery boxes then remove batteries and covers. Lift up on the cover (you may need to push some cable back into the box) and put cover aside. Disconnect cables from batteries and attach to the new batteries. Same procedure, in reverse, gets you back to an operational MPV5.
11/21/2014 9:15:23 AM • Hoveround MPV5... • Answered on Nov 21, 2014
2answers
How do i replace hoveround motor?
First off, are you sure it's the motor causing the problem? Changing the motor is a major job. Basically, you have to completely disassemble the entire unit. Remove the seat and then the batteries. To get to the drive motor, you must remove the pedestal base, and the plastic shroud that covers the base plate. Remove all screws from the top of the unit, and flip over and remove the bolts from the bottom. The control box is held in place by 2 hex screws. Label the motor wires showing their location. Remove motor and replace with new drive motor. Attach motor wires and reassemble entire unit.
9/15/2014 12:38:12 PM • Hoveround MPV5... • Answered on Sep 15, 2014
Is there a way to fix a dead hoveround battery?
The only thing to do is replace the battery.
9/14/2014 12:13:21 PM • Hoveround MPV5... • Answered on Sep 14, 2014
Where are the fuses located
The fuse should be on the wiring harness by the battery connection.
9/14/2014 12:10:42 PM • Hoveround MPV5... • Answered on Sep 14, 2014
How do i disengage the motors on my hoveround wheelchair
Push down on the levers on the front of the unit, between your feet.
9/14/2014 12:09:46 PM • Hoveround MPV5... • Answered on Sep 14, 2014
How to charge chair
You can download a owner's manual here... http://www.hoveround.com/power-chair-and-power-scooter-downloads Charging is on page 24.
7/27/2014 4:29:30 AM • Hoveround MPV5... • Answered on Jul 27, 2014
Where are the fuses on mpv5
Inside the battery box.
6/15/2014 4:18:10 PM • Hoveround MPV5... • Answered on Jun 15, 2014
Need help in raising the seat of a new Hoveround
seat is heavy. first unscrew set screw that holds the shaft sections tight. next put a board across the batteries, then get a bottle jack and start pumping. something's going to give. hopefully it will be your chair raising. Next go to Lowes and buy a pin to fit through the holes. release jack, enjoy your raised seat...
5/30/2014 11:57:44 PM • Hoveround MPV5... • Answered on May 30, 2014
Will not go/ flashing yellow
engage the levers between your feet
5/30/2014 11:48:55 PM • Hoveround MPV5... • Answered on May 30, 2014
Hoveround MPV5 Electric Wheelchair - Used Power Chairs Logo
Popular Tags
25 questions posted
Top Hoveround Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
johnny bonacci
johnny bonacci
Are you a Hoveround Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
  • Hoveround Health & Beauty
Most Popular Question
swivel release bar lock mechanism not
  • Health & Beauty
