There could be several reasons ...the internal memory or storage chip might be defective ...software might got currupted ..... You might try flashing the internal rom if you don't know how to, you better take to a professional to avoid making your device as a brick.
It sounds like a currupt HDD. It could be a bad sector. I would try to format your HDD from the system blade on the desktop. Be sure to back it up first. There is an option in the system menu for this. If all else fails, try another copy of the game, or replace the HDD.
Dear, try inserting a different micro sd card of 1gb in your mobile, if it gets work, then you could be sure that their is a fault in your that memory card which shows storage device not found. it may got currupt. or try formatting that memory card through a computer, then insert it.. it may will work, but if not then its time to buy a new memory card as that card is currupt.
Your maps are currupted. Can't tell you where to find new ones. The company does not support map updates or have any old discs with maps for downloading from computers.
could be a few things. currupt hd (doubt it) to many downloads in the download que. your router could be clocking the ports needed? if this never happened before then its not the router if your account is not in good standing it wont work. if you tried any of those above i got this from m$....
Clear your cache and attempt to re download the update.
To clear the system cache
1.Go to My Xbox, and then select System Settings. 2.Select Memory. 3.Highlight any storage device, and then press Y on your controller.
4.Select Clear System Cache. 5.When prompted to confirm storage device maintenance, hit yes Please let me know if i helped
That is indication that the meida that was written is currupted. use the reset button on the device to attain alteration of the media. Also, replug the device to the computer to perform another media transfer. usually the media pleyer liek windows media, real one player or tues player recognises the device once plug connected. Teh computer program should allow to manipulate by deleting or retranfering another time. Tranfer meida betwweoon devcie should conform with standards. For example, the media should least be over captured esle forcefully currupts the device spaces. Also, tranfer the most intergram or functional media excluding the malfucntion else combining both compromises the MP3 player.
At this point the computer would require an additional storage device to continue to perform as before. Discontinue any further media storage to avoid memory malfunctions like freezing or floating media displays. estimate the situation with the following processes to establish a replacement investment.
1. An entirelly new storage device would be required to replace the old else computer would currupt the entire data in the situation of continues addition to device. A data restructure could be taking place where additional storage overrides existing media.
2. A situation of storage device over achieved could require additional device installations with the process chosen as altermative
3. An additional storage device has to be acquired to replace the old only with consideration of the connnectivity patterns of the computer. a computer that disallows circuit expansion would require removign the storage device to be replaced by another one acquired.
4. Once adding a storage device would require additional memory and graphics upgrades as well.
5. the computer system would perform as before though factoring into the process all additional parts whether in storage or graphics.
An entire pc suit could not fit into a cell phone considering the storage and memory capacity. The phone on the most part would diplay message of insufficiency in capacity or shut down entirely to avoid the process. A currupted functionality in the attempt could requires restore functionality.
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
you have probably suffered a FS crash. You have no choice but the format the drive. (Hope you have a backup) If you dont you will have to run a recover utility like Recover my Files.
